After about a month sitting in the garage, my EB won't start. It cranks, but I can't get it to fire. Checked my Jacobs Coil and found no spark. I had a spare Jacobs Coil sitting around so I decided to switch. Here's what happened:
When I started cranking with the second coil, it fired for a very quick moment and died. This is the first and last time that I've had any sign of spark since the problem. I'm not sure if two bad coils is just a coincidence, but now I'm worried that I might have an electrical problem that is frying my coils or something else? So here are my questions:
- Anyone know of something that might cause a coil to fry?
- Could a bad Unilite Ignition Module cause the coil to not spark?
- Anything else that you can think of that is causing my lack of spark?
My Bronco specs are 302, stock carb, Jacobs Mileage Master Ignition System (Ultra Coil & Box) and Mallory Unilite Distributor with ballast resistor. I've had trouble free starts for the past eight years with this setup.
What sucks most is that Jacobs Coils and Unilite Ignition modules are not cheap.......if one or the other is fried, don't want to keep burning them up.....need to fix electrical problem if there is one.
