BHBronco
In the process of firing the rebuilt 302 on my 69. I have been turning it over a few times, I have clean fuel in the tank and it seems to have reached the carb as well since it drips out of the fuel inlet when I pulled the hose off. I just put one of those inline spark lights in between the plug and the ignition wire and it didn't illuminate.
I'm running a pertronix hei distributor but I checked the hot lead to the coil pack and it only registers about 2 volts with the key in the 'on' position. I also figure I need a ground strap to ground to the engine block to the frame.
