Most of the general wear items are available. Here's our page with offerings for most years and models:
WH Stock Column Parts
It’s the non-typical non-service items, such as a shift tube that are no longer found. We had them for a couple of years, but they went fast, with some models running out of stock before others, but finally the last were sold out.
Not sure who our supplier was, and whether they were newly manufactured, or just old stock replacements someone had laying around. Either way, they have not shown up much as of late.
But keep your eyes open!
Even the shift rods are not always available in reproductions. So if you ever lose one, or go from a six to an eight cylinder engine like you're contemplating, you might have to dig around to find the correct ones.
The turn signal switches have proven a bit finicky too. Not that they don't work well (thank goodness!) but that the wiring colors of the replacement parts don't always match the originals.
Some of this might be mistakes/carelessness on the part of the manufacturers, while some might be the fault of Ford. The reason I say Ford in this case, is because I have worked on several '73 model Bronco steering columns, and out of them all, I came across at least three (but I think it was four) completely different wiring schemes.
And this was with original columns and switches!
Speaking of '73's... If you are ever working on a '73, '74, or '75 model but especially '74!) then NEVER throw away the old parts until you have compared, tested, verified and vilified that you can install the new one and make it work, electrically speaking.
We've talked about this here before. Where the colors don't match, so there is a lot of head-scratching and continuity testing to make sure that the wires being connected are the correct ones.
Few things more annoying than having your turn signal indicators come on every time you hit the brakes!
Sorry, I know you're talking about the physical aspects of the shifter. But since we were talking steering columns, I thought I'd throw some more good news into the mix.
Hey, might as well know what you're getting yourself into.
