MP3 Stereo setup ?
spreadmonkey
Austin, Tx
I'm going to put a stereo in my bronco this week. It has an aftermarket CD player/radio in the dash but that thing is worthless, so I'm replacing it with something different. Need a little help deciding what to buy.
All I really want is an MP3 receiver I can plug my ipod into. Ideally I will be able to put the whole thing in a waterproof box and hide it somewhere or weld it to the floor with just wires coming out. I already have an old PPI 2-channel stereo amplifier from way back in high school, model PPI2240. I have some 6x9s and tweeters and a 10" sub (not even sure if I'll use the sub).
My main goal is to do this as cheaply and simply as possible, can anyone tell me what else I need? I am thinking I will need some type of receiver (not a radio/in dash model) with a pre-amp so I can run ipod>receiver>preamp>amp>speakers. I'm going to fry's and radio shack later but I wanted to ask around here first. I'm sure someone else has done this but I couldn't find anything in CB search, or on google.
bronconate
Edgewater
I have a similar setup to what you want. I have a couple 6 x9 alpine speakers and an alpine sub. I went with waterproof models of both. Mounted the amp under the seat and you can buy the accessory wires that plug right into the amp. I eventually thought about putting a small sub in mine but was told by the geek squad guy at best buy that i would have to run another amp seperate from my 6x9. Of course my amp is small as im not using much, so Im pretty sure if you get a large enough amp you should be able to run all on one. I believe the recommended way is to run a small amp for your small speakers and mp3 and a seperate larger one for the sub being that we dont use an actual head unit. Lot of people on here helped me with my setup but those "geek squad" guys that work at best buy are pretty knowledgable about all the audio stuff.
spreadmonkey
spreadmonkey
Austin, Tx
So do you just plug your ipod directly into the RCA input in your amp using the RCA splitter cable? It seems to me like there would be a real lack of power that way, since typical car audio amps are designed to amplify sound that is already amplified by a traditional head unit.
KyleQ
You can do that just fine - the volume on the MP3 player will affect the volume through the AMP.
Most car audio situations use RCA cables, which are mostly under 5V - look at the pre-amp specifications on the head unit. The RCA cables just provide signal with minimal voltage increase for volume adjustment. The amp does all the work - hence the name. When you use the speaker wires to provide signal to the amp those are already amped by the head unit's internal amp, which tends to wash out the signal after it gets amped again.
When I plan on doing a stereo I will use my MP3 player directly hooked into an amp powering marine speakers. Check out this Pirate vendor - he has great deals.
http://www.pirate4x4.com/forum/showthread.php?t=657610
spreadmonkey
spreadmonkey
Austin, Tx
I stand corrected! Thanks for the info, that makes sense to me now.
Thanks for the vendor link, looks like he has some great stuff. For now I am going to try to use the speakers I have and just try to keep them dry. Hopefully once they inevitably get ruined I will have some money to put towards that nice $205 box of marine speakers on his site.
KyleQ
Yeah - his stuff is at great prices for a 4x4. It makes sense to use marine equipment - his prices are HARD to beat.
spreadmonkey
spreadmonkey
Austin, Tx
Now all I need to do is figure out the enclosure for the amp. I was thinking something that would make it somewhat hard to steal, while keeping it dry and softening vibrations.
I think I'm going to mount the amp to the floorboard, using some rubber donut spacers under the mounts. Then maybe cover it with a steel box and tack weld the corners, use ATV sealant to keep moisture out, as well as around the screws where they come through the floor. How does that sound?
Any better suggestions?
rekoj71
Amps run off of MP3 players work great. One problem with amps is that they generate heat. It's not a lot of it but the amp runs better when they are cool, thats why they have the fins on the sides. To totaly seal it may not allow it to cool properly and they usually have a thermal shut off that kicks in when it gets too hot. If you mount it to the floor board be sure to find a cool location (not over the exhaust). You may be OK if you are just running 6x9 type door speakers since they don't require gobbs of power. Sub woofer amps require lots of cooling.
Steve83
I have an older version of this with a smaller screen, but otherwise identical. It's great, and stores 2GB internally, plus as big an SD card as you can find (16GB?). It'll work with an original radio, and is easily portable to all your vehicles.
KyleQ
12voltguy should be able to help you out for an amp enclosure, probably that vendor as well. I don't see why you couldn't mount it under the dash, it should stay pretty dry under there...
spreadmonkey
spreadmonkey
Austin, Tx
I thought about the heat issue, and it's my biggest concern for enclosing it all the way.
I thought about mounting it under the dash, but I was really hoping to use the extra space to make a new glove box. It's not a huge amp, but it's big enough to where it would rule out a glove box.
12-Pack Jeff
La Mirada, Ca
The rubber feet/stand-offs will make it vibrate all to hell.. just mount it directly to something solid that is your best bet. I've tried both ways and only broke stuff when mounted on rubber bumpers.
Sac '68 sport
Orangevale
X2 with the rubber bushings. No good.
You can try your steel cover idea and if it's small relitive to your amp you could drill some holes in it on the side or something then put in a small 12v fan to blow out the hot air or fresh air in through the holes. I've got my sub amp under the stock back seat and have enclosed the front and back openings of the seat to hide it. For air flow I just stuck a 12v fan so it blows over the amp, no additional air inlets or anything and it works fine, but it's a pretty big space for the size of the amp.
I'm liking this MP3 straight to the amp or amps idea more and more.
Not haveing one since my Ipod shuffle died, are there mp3's out there with EQ's, bass and trebble controls, etc?
22213evl
Rio Rancho N.M.
your better off getting a head unit that has a mp3 input on it as this will allow you to listen to radio also and it makes the hook-up easy
I have a walmart cd player with the mp3 input on the face and i just plug my pod into it, this also lets you remove the mp3 for whatever reason you want.
also I use the head unit to power the 4 marine box speakers, then I run the amp (200 watt) to my 10" bass in the back, amp is hard mounted under the pass seat.
SpareParts
I have wasted 2 head units because of the dirt and moisture. I use a small Sony amp that is hidden under the dash along with a inline level control that I bought from a local stereo shop. The RCA MP3 player I have is very basic and has some sound settings like POP, ROCK, JAZZ... It goes through the MP3 to the level controls with a 1/8" plug on the one end of the cord to RCA's on the other end. The RCA's end is hooked up to the Volume control that I installed under my steering wheel for ease of use. Then there is a patch cable that goes from the level control to the amp and then to a set os Sony 6x9's. It's only 20 watts x 4, I'm only using 1/2 the amp, and it's pretty loud. A better or bigger amp would probably help, but I can hear is going down the road with the 40" Pitbulls and my loud 3" Magnaflow exhaust.
No pictures, it's all hidden, and pretty water safe.
David
junebug
For mounting the amp I used a tupperware box, drilled holes in the sides and then filled gaps around the wires with ATV. I then mounted it under my hood on my passenger fender. I never had it shut off once due to overheating since the tupperware lid was off. When I went wheelin I just popped the lid on and it was waterproof. Looked kinda bad but worked great and thieves never thought of looking under the hood. Amp was a Precision Power 50x4 bridged into two channels.
spreadmonkey
spreadmonkey
Austin, Tx
Update
So here is what I have done so far: I am mounting it on top of the back passenger wheel well--don't have room under the seat and I plan to build a large lockbox under the dash.
I have run all the wires for the amp, including an accesory wire to the "remote" lead on the amp. Ran all speaker wires from front along with :mad: those, enclosed in heatshrink all the way back for a clean look ( I strapped the tube of wires to the roll cage.
I have two 6" speakers in front and two 6x9s boxed in the back. With everything hooked up it sounds great and it's really loud.
I need to go find a volume control and maybe an equalizer. I would like the volume control to be in-line and mounted in the front. Anyone know where I can buy one for a few bucks? Fry's or radio shack maybe?
For the enclosure I am pressed for time so I picked up a plastic box with a sealable lid, $4 at wal-mart. I'm going to run the wires through the side of the box and seal with a grommets or ATV. I have another idea for theft-proofing which I won't share, but it has to do with welding(not to the amp though)
