- Nov 3, 2003
- 51,651
You could also bolt or pop-rivet those supports into place relatively easily I would think.
It'd be easier to do the front part with the grille off of course, and that's a job in and of itself if the bolts are rusty (they almost always are) and/or have never been removed, but the rear part (against the wheel well) should be relatively easy.
I really like the wood approach though! Sounds strange, but it would certainly do the job temporarily and be easy and cheap. Wood is effected by moisture of course, but that can be somewhat slowed down by any one of many coatings.
But wood is not effected by battery acid!
The body mount is replaceable also, as part of the one support brace, but it looks from here like the core support itself is part of the rust-party as well. Is that the case? If so, then the best bet is just to plan on replacing it as a whole. They're available from all the vendors and, though not a piece of cake certainly, should not cause too much headache when installing.
It's probably easier to do the whole thing anyway, rather than fight the tight quarters in there to see how double-jointed and nimble you really are. And the new core support would come with most things already attached. All you'd have to do is add the supports and away you go.
Relatively speaking...
Anyway, good luck Scott. Take the old ones out and have a better look-see at what you're dealing with. Clean and protect as needed, and go from there.
