my car trailer
miikee73
Shadetree Guru
Aloha
After many years of flat towing I finally moved on up to a trailer. Saw this one for sale last week and picked it up for $1200.It's a 2001 16 ft 7000 lb GVW. Hooked up my trailer brakes today and put a back up camera on so I can hook it by myself. Wife is a little upset,the camera was for her car,oh well!
Still need to get tie downs.
What do you guys recommend for tie downs? Saw some 10K lb ones on Jegs site for $49 bucks a pair ,shipped.
pa69broncoguy
Looks like you got a good deal, that looks to be a nice trailer . Its hard to find a nice trailer in that price range. congrads
TwoDalesDad
MIKEe Very nice trailer you scored!!!,, Your Bronco is Very Clean....Pretty little Pony ridding on a Trailer.....hey Are These Lyrics for a Country Song????
moses_m
Nice trailer check the hubs and bearings to be safe.
Kinedyne ratchet straps and chains are what truckers use. So that is what I use.
sprdv1
REBEL
Congrats on the trailer. I picked up a set of ratchet straps from our local swap meet. Mr ratchet or something like that
A few folks still use chains. Those are probably a good option till you find the right straps.
miikee73
miikee73
Shadetree Guru
Aloha
Thanks for all the comments on tie downs.....Now lets talk tires. I did a little reading on trailer tires (ST) vs light truck (LT). Although ST's are designed for trailers they are all being made offshore and there are horror stories about failure. LT's with a load range of D have the weight rating to haul the load ,but apparently are hard to find in a 15 inch size. I know I'll change the tires on the trailer,I just want to hear more stories before I decide.
Amac70
ME
I run trailer tires on all my trailers, 5 trailers never had a blow out. I believe the majority of them are the powerking towmax. and one set of carlisle. keep them inflated to the max and check them. they will be fine. Don't tow at 75mph and expect them to last.
brewchief
For my 7000# trailer I found some 16" wheels with the proper bolt pattern and run E rated LT tires, right now it has 215/85/16s I think but it will probably get 245/75/16s next since that's what the fleet of work vans at my work run.
I'm pretty close to having twice the trailers load capacity in tire load capacity and can find a decent used tire in pretty much any tire shops used tire pile.
NGABronco
Always Learning
N. GA now South Carolina
Go to Tractor Supply, you can get the axle straps for $6.99 ea. and ratchet straps for $9.99 (2"x27'-10K lb.) if you catch them on sale!!;D;D;D
Buy cheap tires and replace them once a year!!! Always carry 2 spares!!;D;D
Nice looking Bronco!!!
jim3326
Appleturkey
I put the same tires on my F350 as the trailer, load range E. I was told that trailer tires aren't speed rated which would explain the bent fenders on my trailer%) No, it wasn't at 75 but 55-60.
I know LT tires don't hold up as well as trailer tires when making sharp turns, but if done right you can avoid most sharp turns and dragging. Besides, I rarely have to make those kinds of turns and I often have to go down the highway with a load, sometimes maxed out. I've only had 1 problem since switching and it was a manufacturing issue, de-lamination.
Jim W.
