Violator
I posted on here about a week ago about a problem I had with my Bronco just dying. I don't want to steal the thread below about my Bronco just turning off. My problem may be a bit more specific. Last week I replaced the ignition coil after getting stranded on the side of the road. I swapped in a good used one just to check if that was the problem and it started right up. I replaced it with a new one and problem solved, I thought. Today, same damn thing happened. Driving down the road and it just turned off. Lucky for me this time I still had the good used coil in the glove box, "just in case". I swapped the coils and it fired right up. I'm not sure how to test to see if the coil is really bad but I did nothing else but swap coils and it runs fine. What possible reason could there be for this? I'm neurvous about taking it anywhere now without a spare coil. Any ideas?
