- Nov 3, 2003
- 48,235
...My old one had egged out so the bushings wouldn't fit. 2 ruined bushing kits later, I got a new, adjustable track bar
The stock '76 and '77 trackbars actually had an oval-shaped upper eye.
http://www.wildhorses4x4.com/product/Trac_Bar_Bushings_7677yr
Earlier models, and the aftermarket bars use the round style.
Doesn't mean yours wasn't in fact egged out though. Just means that they are oval shaped from the factory.
...Do I really need one for a 2.5 inch lift?
What will happen if I need one, but don't have one?
As was already said, you don't "need" one to perform the lift. So if you don't have one your stock one should still work out. But also as mentioned, you're theoretically shifting your axle over to the driver's side by at least some amount. Depending on where it was at ride height to begin with, this could be a non-issue, or on the other hand something work correcting.
To be perfectly centered, you might need an adjustable one. But the truck should still drive decent without one. Only a little driving around will tell for sure.
