My power steering is bleeding...
xcntrk
NOVA
Help me diagnose my power steering problem. The pump has been leaking, it almost appears to be blowing back out the top fill tube but might be coming out of the bottom as well. I'll clean it up, go for a long drive, park and all will be fine. At some point after shutdown it seems to boil out and I'll have a small puddle when I return. The weird part is, the steering is working fine (slight whine) and the fluid level all checks out!
Maybe I have the wrong fluid in it? I'm using ATF/Mercon. Anybody had luck with power steering stop leak, perhaps I should try some?
Pa PITT
Stephenville TEXAS
I was going to ask what kind of pump.. I've seen the stock Ford pump puke out the fluid .. I say the fluid gets too hot.
... I've had good luck with the Lucus fluid.. It also took the whine out of ours.
..I was also going to say you might flush the old fluid out and put in real Power Steering fluid..I've had better luck with it.
... That being said I use dextron IV in my Saginaw Canned Ham.
xcntrk
xcntrk
NOVA
Looks like a Thompson pump. Big round one. My EB didn't have PS stock, so it's a bolt-on kit or thrown together factory system. What fluid should I be running?
Pa PITT
Stephenville TEXAS
.. Well I do think those old ford pump ran the auto trans fluid.. But I might exchange it all for New Power Steering fluid with a stop leak additive in it..Soldier Seal made one.. I used to use .
xcntrk
xcntrk
NOVA
Well I tried a couple things. Drained the pump and the steering box. Refilled the system with Lucas Oil power steering stop leak (thick stuff) and regular power steering fluid (not ATF fluid). I think I got the PS box primed ok and the fluid level properly set (warmed up). Steering still works fine, but the pump isn't sounding too good. Maybe it's just got 1 foot in the gave.
Here's a vid showing the groaning from the pump.
http://vimeo.com/44288298
Anybody know if that sounds bad?
