Bleeding power steering; issue
Bundy
I just finished up my exploder serp conversion with the exploder PS pump and am under the impression that to purge the air from the power steering lines you lock the wheel all the way left and hold it and then lock all the way right and hold it, and after a few times of this it should purge the air. Is this correct?
Well, I jacked up my truck to do this and at "droop" (it's funny because I have about an inch of shitty down travel) my tie rod hits my forward shock mount and I can't get to full lock right so I can't complete the "bleed". The shock mount is already notched, so I guess I could notch it more...
Yes, I know inverted Y sucks ass but I just want to drive the damned thing after 6 months of working on it.
Ideas?
Bundy
Bundy
What if I just got out the ol' sledge and busted that tab off and removed the shock in it's entirety? I don't really need dual Rancho 9000's do I? I am not doing any prerunning LOL
Revelation
IIRC the "Proper" procedure for bleeding it would be to remove the pitman arm so there is no drag on the box at all, then turn lock to lock.
As for removing the dual shocks, if you have a good set of shocks, and are not doing any pre-running style of driving you will be fine with just one shock per corner.
From here it doesn't even look like you could notch it near enough to get your full turn anyway, so I'd lose the shock. Wonder how the PO ever drove it that way?
Or have you installed the inverted-Y setup, OR the shocks, since you got it?
I like dual shocks, but if you intend to use that steering setup for more than a day, it's time to give the lower mount the old-eighty-six. Heave-ho. Heave-a-reno.
If you're still in the deciding stage though, just do like Revelation said and disconnect either the draglink from the pitman arm, or the pitman arm from the box. Then you can debate your options while you're bleeding/burping the system.
Bundy
Bundy
Thanks for the input fellas. I will remove the pitman arm or the drag link and burp it.
I definitely didn't install the inverted Y- I think it came with the disk brakes from the 76' setup the PO had installed. The steering blows all the way around but I don't intend on upgrading until after I get my suspension planned so trying to make it work for one more desert season.
I am gonna knock that shock off and see how she goes!
ransil
I had to bleed my steering separately, had to disconnect the hydro boost and only connect the steering, once that bled out I reconnected the hydro booster and it bled out pretty quick.
Bundy
Bundy
Do I need a puller to get the pitman arm off?
mr incredible
i would dump the inverted y sett up , and go tie rod over. duall shocks not only help off road, but they help controll the short front end with big tires, on the pavement as well .
Bundy
Bundy
Yeah I know, inverted Y blows but I want to wait to go TRO for when I upgrade my suspension.
I tried to bleed it last night- disconnected the pitman arm and went lock to lock about 10 times and it didn't work. I had my buddy watching the reservoir and he said when i turned left, he saw some bubbles which is good... but when i locked right he said fluid came back into the reservoir.
Do I have my lines crossed? Is my reservoir (relocated to fit under the hood) too low to supply the pump? It is only and inch or two lower than where it would be stock.
I am stumped.
