HoldMyPocket
you really have no business in welding these parts to your frame. instead of spending money on welding sticks, practice metal and all that shit, take it to a shop and let someone do it...
Good advice for you:
1) buy biggest sledge hammer you can find
2) smash your welders
3) smash bronco
4) sell all as scrap
5)take scrap money and buy a jeep:-*
I had a Jeep and in stock form they are junk. Underpowered and fragile parts. You would have to get a V8, transmission and transfer case from a real truck swapped in. You need dana 60s front and rear. You need a real roll cage fabricated and welded by a someone who is skilled. Forget about getting a TJ if you are not a good welder. All the stock parts and brackets have to go.
The Bronco has less fabrication because it was well engineered by Ford in the begining.
So before you step out your front door in the morining you had better have a good professional welder to repair the broken jalopys called new cars.
My welder who is going to fix my jalopys is going to have to weld the EPA door shut. Then we will have jobs and money, not funny money, to buy real cars not jalopys that we are pigeon-holed into.
If I get a professional to weld my chassis up and I get my welding certification for future use will I not be pigeon-holed anymore? I am building a Bronco because it is better than any comparable manufactured today.
I am going to get a short wheel base F-350 4x4 with a 6.2L gasoline powered V8. I am going to run it into the ground for ten or twenty years.
3) smash bronco
360 what state are you in
