- Aug 3, 2012
- 101
I purchased a 351W out of a '95 Ford F150 at the salvage yard that I will be swapping in my Bronco soon. I disassembled the engine and took the short block to a local machine shop to check it over and do some minor machining. The machine shop said the block is in great shape and I expect to be getting it back sometime this week or next week.
I will be using the Ford Explorer serp system with Saginaw dual return P/S pump (currently this is what I have running on my 302).
I'll use all of the EFI stuff from my 302; I found a Lightning lower intake that I'll also use.
As I try to get my ducks in a row to have everything ready to build this thing I have a couple questions.
I have a pair of GT40 heads from a 96 Ford Explorer that I was going to put on. I did not take the heads to the machine shop, but now wondering if I should. I also thought about investing in a set of World Products Windsor Sr. heads, but I don't know that I want to spend that kind of $$. Head work at the machine shop for the GT40s would probably be less costly than new World Products heads, correct? I've looked over the specs of the WP heads and compared to the specs on the GT40s so I'm sure there would be some performance gain, but I just don't know that I want to spend the money. Thoughts?
As far as cooling goes, since I'm running the Explorer serp system, will this water pump work?:
https://www.summitracing.com/parts/bra-1656/make/ford
I think I read somewhere that I'll need a 28oz harmonic balancer, is that correct?
What about radiator hoses? Does anyone have part numbers of radiator hoses that worked for them? I have a Champion aluminum radiator with inlet and outlet orientation for the 5.0L.
I purchased a new MSD distributor with TFI module to work with the roller cam from Summit and oil pan for 351 from Duff's. I have long tube headers that I am hoping will work with the 351W.
What am I missing or not thinking of for this swap?
