Name this bolt head
OK, off an Atlas. It isn't allen, it isn't torx. It looks like torx but the corners are rounded instead of pointed. It is female, requires a male tool. In a pinch a torx bit works, but it doesn't fit right. I tried a handful of tool places and they just scratch there heads. I tried finding something in the Snap-on catalog, didn't find anything.
So what is it?
Fathom
Los Angeles
Look for "Security bit" kits!
I bought one with over 100 bits (From Fry's Electronics) and it has several that may work for you!
Good Luck!
Brian
Broncoman
http://en.wikipedia.org/wiki/Polydrive
Polydrive or RIBE?%) I dunno
Polydrive, also known as RIBE or RIBE CV, is a fastener specification. It is used primarily in the automotive industry.
A polydrive bit has 6 teeth at equal spacing and with flat tips to the teeth. Size is determined by diameter at the star points.
Functionally, it is similar to torx and spline drive, all of which are systems using internal bit-socket drivers along with specially-designed bolts, screws, and other fasteners. Its primary advantage over older fastener driver standards, such as the common Phillips head (and its sibling Pozidriv), is that it resists cam-out, and is thus used in higher-torque applications such as brakes and driveshafts..
I have full sets of allen and full sets of Torx. None fit it very well. One of the torx worked good enough to get it off, but it wasn't the right size. Like I mentioned I took the bolt into a couple tool stores, they went to the torx right away. Then they started looking for one that fit right and realized the same thing I did. The tips are not pointy like a torx, they are radiused. Nothing fit right. I was looking at the star tools but have yet to find a good picture of the tip and see if they are the same as torx or not. If it was a simple answer I wouldn't be asking the question.
Biggest thing...
Note that there are no sharp corners. It is a stady radius all around the inside weaving in and out. All the normal 6 point fasteners I see (allen, torx, polydrive) all have a sharp outside corner, not a smooth flowing radius that the bolt shown has.
OK, that's it. It is a Star drive.
Why can't they just use normal fasteners?
RIbronco
Costa Mesa, CA
Looks like Torx Plus to me. They have a higher torque capacity than a standard torx drive and the driver bits last much longer.
I was an engineer on a production line that used thousands of them per day.
OK, back to not sure what it really is. I did ask over at AA and they just say they use a tox bit.
And we are not hiring right now. We have a waiting list to get into our department. That was a special project, I actually did some of the work at home in my garage. I don't drink Rat Bastard at work.
