I don't think thats a 2150, but knowledgeable minds will jump in here.
But as far as rebuilding it if it's leaking onto your intake it's likely it will need some machining. The bottom of the carb needs to be very flat and if the nuts were over-torqued (common) the carb will bend and the bottom gasket can't accommodate that change.
You've also got a fair amount of rust within that guy. The choke flap (or w/e its called) and some of the linkages look pretty rusty. Certainly could be minimal as an issue, but would require some steps of clearing all that rust off. A kit is going to replace your seals, gaskets, springs, and power valve only not those rusty bolts and flaps. But any big box auto parts store should have the kit you need.
Sourcing a cheap-ish carb is not as easy as folks will lead you to believe if you need to go that way. I had to source some parts from nick in delaware, I was lucky he had them.
