Look at Tom's new Hydroboost bracket. I'm likely going to need to go that route. I saw another thread about an ebay bracket and it looks the same or similar. It uses the same linkage, but literally shifts everything over a little. I have the stock booster, which might work, but I'm leaning towards using that regardless.This has been really interesting to read, another reason why I love the site always something cool to check out. When I first saw that intake I questioned if you have enough room where your brake system would go . I have a TrickFlow intake, I think it’s the Street Heat. I had vacuum brake system with traditional angled bracket. I had to notch it. Recently I installed a Hydroboost , I thought for sure a hydroboost would surely have no interference. I still had to shift it and move it over a bit. Sorry I don’t have a front view to show clearance.
OK, lets try to keep this somewhat factually accurate. (and I'm as guilty as anyone...) But the Crank turns TWICE as fast as the cam. and the CAM turns half the speed of the crank. So there's that.Look at Tom's new Hydroboost bracket. I'm likely going to need to go that route. I saw another thread about an ebay bracket and it looks the same or similar. It uses the same linkage, but literally shifts everything over a little. I have the stock booster, which might work, but I'm leaning towards using that regardless.
Bax, as far as another trigger wheel on the balancer, I've thought about that as well, but the crank turns half as fast as the cam...I thought about telling the computer it has twice as many teeth or something, but it would still pass whatever missing tooth it used for #1 twice so that would not work is my understanding.
here's some pics.
1) Yes, thanks for that clarification, I wrote it so quickly that I miswrote the first part but my explanation was correct. I went back and edited my post. Crank twice as fast.OK, lets try to keep this somewhat factually accurate. (and I'm as guilty as anyone...) But the Crank turns TWICE as fast as the cam. and the CAM turns half the speed of the crank. So there's that.
If you use the reluctor wheel from the Explorer damper, you can see that it has a missing tooth, or a bump. The computer sees that bump, and it knows it is at TDC either for cylinder #1, or maybe #6. So it needs to know whether it's #1, or #6. Enter the cam phaser. The only reason why an EDIS computer needs to know the cam position, is to discriminate between #1 TDC, and #6 TDC. It also provides a convenient way to set the base timing, so it allows the mounting hardware on the crank trigger to be "mostly good" and it can be trimmed by the cam phaser.
I went out to the garage this morning, and I happen to have a full Explorer front dress, and an explorer timing cover loose. Also have a early SBF timing cover. As I thought, the early cover is deeper in the location of the eccentric. BUT, there is still plenty of room to add a trigger wheel to the cam...BECAUSE the Explorer uses a silent chain, and the Mustang 5.0 uses a double roller chain, and it's about 1/4 inch thicker. (I THINK the SN-95 uses a double roller chain as well..not 100% sure...doesn't really matter.)
So you could pretty easily convert your front dress to Explorer serpentine with the Ford crank trigger. Then you could build a cam trigger wheel to fly past your cam phaser sensor...that you could mount in the accessory boss in the cover. But you will have a challenge with micro adjustments since the phaser will be "fixed." Obviously, any offset between your cam and crank triggers could be mitigated in the code. BUT YOU HAVE TO learn the offset.
But this is where it's gets interesting. If you have a good crank trigger, and you know the cam offset, then why not just let the crank trigger control everything. The only thing you lose is sequential multiport, but Ford triggered bank to bank on every non-HO EFI system during the EEC4 days. And anyone that has ever run a 1-5-4 cam in a 1-3-7 computer knows that it really doesn't matter at all.
So if you tell your EDIS that you are running crank trigger only, and you let your coil packs run waste spark...then the spark is going to happen at the right time, and the fuel is going to be lost half the time. But if you go bank to bank...even that won't matter. You will have to find some way to set initial timing, but that's never not true. here's some pics.
4) So yes, I could prob convert to Explorer front dress... to get a robust crank trigger, and a serpentine system that is compatible with my future vintage air compressor. It also adds another inch between fan and radiator, and this would help to keep my engine cool, and keep James Roney happy.Thanks again for the detailed post, I appreciate it. Gives me more to think about.
That's a really good thought! As for threaded magnets, I was sure this would be threaded when it came so I'm a little surprised but no. I did a search to see if there are any and well, there isn't much around. Found this, but it's not like its the magnet that's threaded. It;s a magnet that is probably epoxied in there and they charge $40 to epoxy it for you.With the aluminum you may be able tp peen the edge of the magnet into place as some extra insurance. Do they make threaded magnet inserts?
