Need an electcrian
sbarb
Laurel
as i posted I have no brake lights. the PO had a trailer and the plug was messing me up.I snapped and cut the whole damn mess out. with the help of a test light i was able to get everything working but the brake lights.I can't call the PO and ask what the he** he did because i bought the truck at an estate sale. I was under the dash messing around and found a hot wire splices from the brake light switch at the pedal to the horn button{it;s on the dash by the way} and everyware he made a splice hr used those little blue things yop squeeze with pliers. There was also a plug on the left side of the frame over the gas tank I had to cut out also that is why I got what lights i have. Can someone, an electircian maybe help me the old girl has to go through inspection the end of the month, This is driving me crazy!!:(
BronCowie
Old Timer
Vancouver, WA
You can start by getting rid of those squeeze on splice connectors; they are bad-news. Those were causing me greif a few months ago... gone for good now. And take the horn off of the brake circuit. Check your brake switch to make sure it is passing voltage through when you push on the brake pedal which closes the switch. If it is working, follow the wire back to the rear. Suspect any other sqeeze on connectors in that run.
