Need an interior Measurement
ynotcycle
Wold a member provide the measurement from the floor, DS and PS, to the top of the metal on the dash? Should be the same.
Thank you,
Tony
Back to the top.
Should be an easy one for once, but I’m not near the Bronco right now so can’t be the one to provide it.
Hopefully someone is.
jamesroney
Fremont, CA
Where is the “top of the metal on the dash?”
If you have the dash in the Bronco, that part gets covered by the dash pad. So there’s no good place to measure.
Here are some pics that should get you what you need. (And yes, the numbers are the same on both sides.)
22-3/8 from floor to cluster screw hole, and 16-15/16 from floor to edge bend on the dash.
Good luck!
jmhend
Good luck!
You had me curious so I make a quick measurement on my 76. To the lower dash seam I have 16-3/4” from the floor.
