Cool. Thanks.
Must've been an odd one though, to use the 368A bearing. All the half-tons I have listed from '57 to '77 using the 44-5F use the same Set-37 and Set-45 combo.
I don't see anything listed as an HDR in my book at all.
There is an 5-HDF and a 44-6DF listed, both available with the 368A, but they're showing up only on 3/4 ton trucks in my Timken book.
Seems consistent too, with the "HD" designation usually meaning Heavy Duty with 8 lugs wheels.
However, some of the 1/2 ton axles use the LM104949 bearing, which is virtually identical to the 368A. I wonder if someone just put the wrong number in there previously? Might not even be "wrong" since they're such close relatives. Maybe just an "optional" number?
Anyway, other than more money, the new spindles will certainly simplify the issue. As long as you're using the Ford hubs under those older GM 6-lug rotors that you re-drilled? The hub that takes the #4250 seal? And not the #471271?
Now that you have Ford rotors too, I would presume that's what you're using. It's just that, with two different seal numbers, it's possible you could have another issue to overcome. I didn't compare dimensions though, so maybe they both work.
You'll know soon...
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
(edit: Nevermind. They must be the same where it counts, or we wouldn't be able to use the 4250's on the GM spindles in the first place. Differences must lie in the outer dimension or some other design criteria)
Let us know.
