need F250 shock tower pics
cupcake
Got my towers the other day and would like some pics of your install for reference. Thanks
WyleCoyote
I don't know if I did it right but heres my pics! I lined up the bend in the shock tower to the top of the frame, then welded it all around. You can raise them up higher, and you can cut the sides where it is angled and straighten the angle too. There is a pretty good write up around here somewhere on it, maybe in the FAQ's...
broncotom
CO,100 Miles to Moab
here are a couple. I can find some more if you tell me exactly what you are looking for.
broncokak
I want to do this to mine too. Some say to run the top of the shock tower up until it almost touches the inner fender. What would give the most amount of travel for this type of shock mount?
garberz
Bronco Influencer
Conejo Valley, Ca.
If you want the most amount of travel, you need to get the longest shock that will fit when it's fully compressed. I'm doing this to mine right now. I have 3 1/2" coils, and I'm running Bilstein 7100 short body 14's. The compressed length is 19.6", so I measured my travel without the coils in. With the axle fully stuffed, the lower mount to the bottom of the fender well is 21". I have a 2" BL. So I need to mount them within an inch of the bottom of the fender well. Those shocks extended are over 33" long. Thats way more than my truck will flex. I could put in taller coils and still be ok.
NicksTrix
do yourself the favor and mock it up. this way you are sure you have the shocks in the right location and the mounts in line with each other. cycle it with the springs out to ensure you are correct on the bump.
broncokak
This is what I was planning on doing. I need to replace my front coils as mine are pretty stiff old school coils. At some point I'd like to go long arm too but that will have to be later on. Will there be a big difference between the stock and long arms?
garberz
Bronco Influencer
Conejo Valley, Ca.
The longer arms have more leverage so they will flex more. They should generate more droop. You will benefit from a longer shock. The most droop I could get was 28", by picking up the rear tire with a forklift.
cupcake
cupcake
Hmm now that I played with it. I dont think the f250 towers will work for me. I need to make something different.
And can you mount the lower end of the shock outboard of the bracket with a longer bolt and a bracket to pick up the end of the bolt?
broncotime
Grapevine, Texas
Seen that thread, Thanks. I ended up stitching two mounts together to extend them two more inches. I'll post some pics by this weekend.
That's exactly what I did and after some grinding and paint, you can't even tell. I was able to squeeze in some short body remote resovoir Bilstien 7100s with 14 inches of travel. I've got Cage extended arms and get really good flex out of the front end. I did have to put taller bumpstops in to stop the tires from hitting the inner fenders and possibly bottom out the shocks (35 inch tires).
malcolmzilla
Calgary, AB, Canada
I located the bottom of my F250 towers about 1/2 way up the frame, this put the top of the tower within 1/2" of the fender for maximum shock length with no body lift. If you have a body lift then by all means extend them as high as possible to get a longer shock length...
You can also relocate the lower mount on the CAGE or other arms, on my to do list, esp. if you have no body lift like me.
