Need help finding this seat belt device
doghows72
The seat belts I bought from Toms has them on em. Maybe call them and see or hit the wrecking yards?
mjramacher
there are some early 90s chevy pickups with those type of seat belts not sure if they will work ya just throwing it out there.
Brnco302
That way next week you will be able to get it for 1/2 off.A steal at 17,500.00
What type of console do you have? A Tuffy has the strap to hold the seat belt up out of the gap.
On other styles of console you might be able to add your own.
Desert Dweller
Central WA
Those are GM seat belts... I have some like that out of an S10... The retractor sets flat on the floor so it functions correctly .:cool:
miikee73
Shadetree Guru
Aloha
if you have the console all the vendors are selling,chinese Tuffy knock-off,like mine there were two holes on each side about 6in apart ,about seat bottom height .I just ran a black zip tie through them and it keeps the belt from falling into the abiss.You could get fancy and rivet or bolt a nylon strap there
bteutsch
Bronco graveyard has them.. I bought them but haven't figured a way to pull the stock seatbelts through them yet.
Bradsp8
Bradsp8
Thanks for the replies. If any other ideas let me know.
To pull the belts through I was thinking the end that bolts to the floor could be pulled through from the top of the sleeve. Is that end not small enough to be snaked through?
Glass Pony
Sussex County Delaware
Bradsp8,
Are these what you are looking for? They came with TBP seat belts.
I'm in the process of installing my fold & tumble back seat and I'm not going to need them back there.
Bradsp8
Bradsp8
Seat belt sleeve/stand
Glass Pony,
Yes, those look great except the color. I was looking for black or an off white similar in color to the seats. Do you think my existing belts could be inserted through that sleeve? Or is the sleeve split down the inside so that the belt can be inserted?
Did the "L" brackets come with them?
I'll send you a PM.
Thanks.
Glass Pony
The sleeve is not split but I imagine the way they put it together is pull the buckle(what attaches to floor) of the belt through with a wire or something. The width of the buckle I pulled out was 1-5/8".
The L brackets came with them (I may need them) but they aren't anything special just a piece of 1-1/2"x1/4" flat bar bent in a angle with a couple of 1/2" holes.
As for color maybe that Krylon Fusion paint for plastic may work.
If you can use them send me your address in a pm and I'll throw them in a USPS shipping envelope.
I saw your pm and I don't want anything for them but if you feel the need, just make a donation to your local animal shelter.
