Need help: Sport utility cross bar
Wingo4x4
Myrtle Beach
Just purchased a perception kayak and I want to be able to carry it with a my paddle board at the same time. I have a family roll cage but I'm thinking of purchasing suv cross bars to mount to the roll cage so I can have more versatility. Has anyone done this before? I've seen them mounted to hard tops but I'm not sure if the cross bars will fit on a 2" roll cage.
I would think that most crossbar manufacturers have different adapters by now for different tubing sizes. Even if most are intended for either a metal roof or drip rails or whatever, lots of companies make clamps and brackets for tubing.
Sorry I don't have an answer for you for sure though. Haven't seen many done up, and none close up.
Like you found in the pic above, they have been done. Maybe someone will see this soon and have an answer for you.
In the meantime... Back to the top;)
DuctTape
Bozeman, MT
Look into the nrs quick and easy crossbars. Less than 200 bucks. Fab your own rain gutters and mount them to the roll bar.
We have one rig setup with kayak racks like your first pic, and another rig setup with nrs bars. I like the bar rig because it is wide enough to put two kayaks flat, and it doesn't wobble like the racks do (I use a supplementary strap on the racks to add rigidity).
The kayak racks will probably not mount directly to the roll bar. If you don't have access to fabbing rain gutters, you could pretty easily drill your roll bar and mount some trex to it, then mount the kayak racks to that. You could also get some exhaust ubolts and work out a rigging rack option that way. Lots of ways to skin the cat but my bet is it will be hard/expensive to get an off the shelf solution.
Personally my plan for rigging racks to my topless bronco is to fab a rack and towers and mount to roll bar by drilling through (or maybe welding nuts). But if I get short of time I will go the nrs rack option like I discuss above.
Thule and Yakima have ridiculous pricing these days.
Sent from my iPad using Tapatalk HD
68rockcrawler
Check out Fourtreks:
http://fourtreks.com/roll_bar.html
They make roll cage mounts. Maybe you could adapt something of theirs to Thule or Yakima cross bars.
Or Google "billet aluminum roll bar clamps". There's definitely something out there that you can adapt and use.
