civilgee
I'm doing the conversion from vacume to electric wipers and all I like is wiring the intermittent switch. I do not have the wiring harness for the switch so I need your help. I tried unsuccessfully this weekend to figure this out (I blew a lot of fuses). Here are the prong layout on the back of the switch, I numbered each one so that each can be identified:
. \ (1)....__ (2).... / (3)
........................ l (4)
. \ (6)............. / (5)
Here is what I could determine with my electrical gauge:
Prong (6) is for the washer
Prongs (1) and (2) are for hot wires
My question is as follows:
Which prong do I attach the hot wire from the fuse box?
Which prong do i attach the RED wire from the wiper motor?
Which prong do I attach the BLACK wire from the wiper motor?
Which prong do I attach the WHITE wire from the wiper motor?
Which prong do I attach the BLUE wire from the wiper motor?
Do I have to connect the ground wire coming off of the switch?
What size fuse do I need to use?
Thanks in advance for your MUCH needed help. This little wiring project is killing me!!! I had to walk away from it several times to keep from breaking something (most likely it would be my fist that got broke.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
