Need help wiring an alternator
Mosey
Chapel Hill, NC
Hi guys! New Bronco owner here, Ive had my 1970 Bronco for about a month now. So far the only thing I've done to it is i put in a choke cable going to the carb. Last weekend i put in a new battery and by Tues it was dead. so I tested everything and I came to the conclusion that it was the alternator and the voltage regulator(which looked like it wasn't even grounded when I bought the vehicle, it was just flopping around in the engine compartment). So I went to autozone and bought a new Duralast 61amp alt and put it in, wired it up the same exact way as the one before it, and this started getting really hot and smoking:
Here is a pic of what it looks like:
And i'm pretty sure this was on the STA space
And then this is how it was grounded before:
And heres the starter solenoid:
What am i missing out on? ?:? Obviously for photo purposes I didn't put in back on the motor yet.
Phil76
Aransas Pass, TX
Do you have a ground from the block to the frame? We had similar issues, and grounded battery to block, block to frame, and a ground strap from back of engine to the firewall. Can't have enough apparently.
broncodriver99
Glen Allen, VA
The STA terminal is voltage for an electic choke. I know this because Viperwolf told me.;D You don't want to ground that. Either of the other 2 bare studs can be used as a ground. Just rewired my alternator as well.
Steve83
This is the first in a series for slightly newer trucks than yours, but the alternator wiring is the same:
Scroll down to the caption & see the NEXT several for more info.
You grounded the heavy Bk/R to the body, but it goes on the alt ground stud. And nothing goes on the S (Stator) stud except an electric choke wire (if present).
But you'd solve a LOT of current & future problems by upgrading to a 3G alternator:
...and also by staying OUT of the zone.
M
Mosey
Chapel Hill, NC
Hmm, I tried everything that you guys posted thanks! However, now it does nothing at all when I try and turn it on. I have an electrical book about the bronco coming sometime this week, so before I do anything else to it, I'm going to sit down and go through it thoroughly. It's actually the 1970 Original Ford Truck Shop Manuals Volumes One thru Five. I got it off eBay for $28.00 which is really good seeing as everywhere else I saw the whole set going for $100+ most of the time.
Originally, I took off the alternator that was on there and wired the new one back exactly like it, now that I think about it that was the wrong thing to do seeing as that's probably why the alternator and battery went bad in the first place.
broncodriver99
Glen Allen, VA
There is a good chance you cooked it by shorting the Stator terminal. May not have fried the windings but the built in rectifier is probably toast.
That book will be a big help, but if you search on here you will find quite a few threads for troubleshooting charging problems. Between them you will be able to get a good understanding of how the alternator and voltage regulator interact and where and what to check.
Good Luck.
BwoncoHowie
C-4 Wizard
If you dont have a white wire with a black tracer, then your vehicle is not equipped with a stator wire. in which case you would connect nothing to stator terminal on the alt. Treat the black as a ground and nut it to the ground stud on the alt case. The orange wire is always field terminal. Check also or trace where the (S) terminal wire from the voltage regulator to see where it goes. I also noticed you put your wire clip on the stator terminal, thats a NO-NO, the clip should also hook to the grounding stud.
~BH~
BwoncoHowie
C-4 Wizard
The smoke and heat probably came from the fusible link. When I blew my fuse link, I dug into the harness and elininated it. I installed a solid wire and a circuit breaker in line with the harness.
If you blew your fuse link, you will have no power to the dash, electrical controls, or instruments.
~BH~
