dbridgs
- Jun 19, 2005
- 125
I have a 1967 bronco and am planning to install a james duff long travel suspension, nv 3550, and a 2" body lift. I would really like to get something stronger to replace my dana 30 and small bearing 9in rear end. Ive talked to currie about having them build one but its way to expensive for me right now since that cash is tight. I would like to install a full width front and rear end since this seems to be the cheapest, strongest, and easiest to find swap. does any one have any recomendations? will my tires stick out way to far? what trucks (model and year) are the best to pull the parts from? what modifications will i need to do to make these fit in my EB, will this be a big pain? I really need help with this I only know a little about front and rear ends and what is best. thanks
is it wise to find a built front and rear end from someone else? or should i scour the junk yards and do it myself? how do i check the straightness and condition of the housings and components?
