Need Help With Fitting New Wheel Tubs..
Mill KNOB
Rock Hill, SC
I am in need of some advice.I am woundering is there any set way to make sure before I weld in my new Wheel Tubs on??? I have mine clamp in to the inner fenders right know and they look pretty good. But I want to make sure that there is notthing out there that I need to know... One thang that I done was making sure that the Wheel Tubs are setting level in the Bronco...
Any help would be very appreciate...
maggard12
Whitesburg, Ky
wheel tubs
There should be a lip on the inner quarter where the wheel tub should go. I would say as long as you have your tub in the lip, they are level, look good and are butting against the inner quarter you are good. I have only replaced one of these so you might want to wait for some other advice.
broncorick
I have replaced them, not as critical as rear tubs. Basically flush with edge of outer wall. They tie into the front piece, but that is more a fitament issue, but no exact measure required.
Mill KNOB
Mill KNOB
Rock Hill, SC
Thanks for the help.. I will just put them in..
