Can't see the top totally, but by the look of the general shape and the dual wire bales you've got a GM based master. Could have been bought individually, or as part of a power brake kit.
Are the ports all one size? Are they only on one side of the master, or are there ports on both sides?
Most of them seem to end up being 1 1/8" bores, but are available in various sizes and configurations. If it were me I'd get one with a 1" bore to be more like the original. Or I'd just get an original!
If you still have the original soft hoses from the master down to the distribution block on the frame ("H-block") then an original style master will be a cinch to attach the hoses to. If it's already go newer hoses, then sticking with this type is probably your best bet.
If buying one locally you could use different GM vehicles from the mid-sixties to the late-seventies and be pretty safe. Other than the different port sizes.
A '65 Corvette with manual brakes for example probably had that style, with a 3/4 or 1 inch bore. A '67 'Vette with the same manual brakes probably still had a 1" bore but I don't know if there were any internal differences for the recently included disc brakes on the Corvette.
GM trucks used similar masters, but I don't know what size the piston is.
Since you show a booster, you may be stock with either modifying your new master (the two mounting holes could be different spacing) or buying one from one of the vendors like us (
https://www.wildhorses4x4.com/category/s?keyword=master+cylinder) that are already the correct bolt spacing and register size, has a deep well piston but includes a spacer-insert if your booster rod length requires it, comes with a relatively standard 3/16" port size, and has ports on both sides to aid in choosing which way is best for your individual setup.
So it does have some advantages over taking your old one into the store to compare all aspects to new ones. If you've got a patient and helpful counter person where you shop that's not too big of an ordeal.
They are 1 1/8" bore though, so while that's generally fine with your booster, you would get noticeably more "assist" for your leg with a 1" bore. The greater fluid movement of the larger bore is not required with drum brakes, and the extra power of a smaller bore can still be an advantage even with a booster.
And here you thought this was going to be an easy, "choice-free" decision!
;D
