I picked up this Rear Dana 60 axle from a local junk yard. They said it is out of a 75 F250 4x4. The BOM# is 603381-11 which comes up as a Standard 3.73 out of a 1973-74 F-250 3/4 Ton HD 4x2 Pick-up - Full-Float.
So I don't know anything about axles. But I thought that in an axle without a locker or limited slip if you spin one wheel the other goes the oposite way? Well on this axle the both turn same way and you cannot hold on to one and spin the other.
So in looking at this axle for being out of a 75 it is pretty free of dirt and grime and has a black paint still on it and the ratio tags are missing. So I decided to open it and see if it had a locker or limited slip and verify the ratio. Here is where I am kinda stuck.
On the ring gear is the following numbers:
7676 6 18 96 Dana T32503MAIL 605 46 - 13
So I am not sure if this is actually a 3.73 ratio and this looks like a open diff to me so why do both wheels spin? I don't see any welds on gears or anything.
