Need location for hard top stake bolt holes in the rear corner posts.
Bradmis
I have a brand new tub from Rust Belt broncos that didn't come with the mounting holes for the rear hard top stakes drilled. I'm installing a used to on a new body and really want to fix the two rear corners of the top in the proper position. I then need to drill the mounting holes in the quarter panels for the hard top. Squaring the top to the body without being able to locate the rear corners is proving difficult. I asked Rust belt if they had a template and was told to mount the stakes on the top and then put it on the truck, mark and drill. That makes no sense since the stakes are inside the corner post so there is no way to mark and drill. It looks like the stakes should be flush to the inside corner of the cavity on each corner post but measuring and drilling 3 holes in the blind seems way harder than it should be. Does anyone have a diagram or a print that shows size and location for these holes.
