mofoco1
I am installing new hard stainless steel brake-lines on the EB and am almost finished. I hit a snag with the front tree that comes down from the proportioning valve to the top of the differential. Seems that the new flex-line needs a spacer and a longer breather bolt. The reason for the spacer is that I am using hard SS line with reusable alloy ends to 3-AN adapters. The adapter sticks out farther on the tree and there is no way with out a spacer the line will clear the housing to go to the passenger side. So here's my ? is there such a thing as a longer breather bolt, or can one be made without to much trouble. I had thought of getting a longer SS bolt and then drilling it thru, drilling the top with a larger bit and tap to thread a nipple for the breather hose. Anyone had to deal with this? any ideas are welcome. Thanks.....Mo
