Need Pictures of Front Drums
jperry1290
I need pictures of front drum brakes (pref from a 1970) with the drum removed showing all of the springs attached. I pulled the parts off and cant find the way they go back on. I have a haynes manual but the pictures dont appear to be the same as my set up.
airbur
Castle Pines, CO
Sorry...don't have any of front drums..but here are my rears before the rebuild...
ManTruck
Heres from a D44 but should help.
Airmapper
Foolproofness Tester
Bowling Green, KY
Here is the front drum setup of my '66 with a D30:
If you need one close up, let me know and I'll run out and take a few pics, that was one I already had on the computer.
Airmapper
Bowling Green, KY
Per request, hope these show it better. The spring going all the way across above the center hub is using the same holes as the main springs.
I don't guarantee those to be correct, but the way I replaced them is since I had everything new I pulled off the old shoes and springs as a unit, then built the new next to that using the old as a template to make sure I had everything in the correct location.
