Need power brake booster bracket hardware
Jonboy69
I am thinking of adding a power brake booster & I have the bracket that mounts the booster to the firewall but not the hardware that connects the booster to the brake pedal & am wondering if it is difficult to fabricate/make these pieces ? Or if anyone sells just the hardware kit ? The guy that I bought the bracket from said it was real easy to do but I cant seem to figure it out. If I had a pic of what it should look like, I could probably get it figured out how to fab one up.
broncnaz
So in other words your missing the bellcrank piece? when I installed power brakes I got the bracket from a vender but it wsnt bent correctly so I had to rework it.. If I had to do it again I would build my own. You can make the bellcrank pretty easy just some 1/2 pipe I think(maybe it was 3/4") and some flat bar and a couple of bronze bushings that fit your pipe and the bolt that goes through it. Should be able to find everything at the local hardware store.
