Hoss408
- May 31, 2013
- 43
Okay, guys, I need some help here, not sure exactly what I did, but I did it big apparently. Changed the water pump and thermostat on the '73 today, been heating up a little too much in traffic, etc. No big deal, right? Finished up, filled the radiator, fired it up to let it warm up and pull the coolant through, everything fine for a few seconds, and then BAM! Suddenly I've got oil flying everywhere. Yes, oil, as in motor oil which should have nothing to do with a water pump, right? And when I say spraying, I mean fan flinging it, coating the entire engine compartment, underside of the hood, and the Harley parked next to it before I could get it shut off! Also, noticed a big puddle of coolant in the little valley on the block directly behind the water pump. Any ideas on what the hell I could have done and how to fix it?
