- Nov 3, 2003
- 51,619
Unfortunately, it could be either/or, OR the NSS we were discussing.
The wire should only have power when the key is turned to the "START" position of course, so you can only test things with it in that position, but because the NSS is physically in-between the two, and it's job is literally to keep the starter relay from working, you need to add that to the list of possible culprits.
So, in order of appearance, counting backwards, you have the 90° connector at the relay, the wire itself back to the firewall area, the potential connector at the firewall with wires going down to the transmission, the NSS on the transmission, the wire between the NSS and the ignition switch, and the ignition switch.
Lots of things to wonder about, but it's fairly quick to follow the wire along to each junction to see where the power stops.
Why not just try shifting the shift lever into neutral from park, to see if that changes things. Turn the key to start, then run the shifter through it's full range.
Can't hurt to try, takes a few seconds, and might give you another clue if you do hear a click under the hood when you get to certain points in the shift range.
