- Aug 24, 2006
- 1,328
Hello,
So when I tore this bronco down... a few years ago...
I got rid of the old suspension not thinking it was going to take this long to get it back together... I know... lol
I'm at the stage of ordering shocks and need some measurements.
Here is what I have.
3 1/2 Lift (WH progressive coil front, 11 pack leaf rear),
Extended Radius Arms front (All For Fun)
Long Travel Dual Shock Mount (Bloody Knuckle Garage Hoops).
My front measurement eye to eye is 23 1/2". Rear is 21 1/2.
I do not have the ability to flex the suspension at the moment and kinda want to buy at least the front shocks prior to fully welding the hoops in since there is a little room for adjustments there in regards to alignment and height.
So those of you with a lift and long travel set up, what are you seeing in regards to full compression vs full extension? I have the eye to eye, but need those measurements to get the right shocks.
Initial plan was just running the standard dual James Duff 70/30's up front but now I'm considering single FOX 2" or 2.5" shocks with external reservoirs'. This will be a serious mall crawler;D with occasional Desert running and mild crawling/trail rides.
