hess77
I've got a few issues that I'm trying to sort through right now, open to advice and opinions. Two things worth mentioning: a) I'm just learning to weld sheet metal, and b) I want to do everything myself.
My two issues (for today):
1. There's a significant amount of rust just under the upper lip of the rear quarters. I've seen guys use a piece of copper backing to weld holes shut, but seems like it would require a ton of grinding after the fact with my as-of-today poor welding skills. Not sure if I should bite the bullet and replace the quarters with aftermarkets? Other thoughts?
2. It looks like the PO put lower skins on the outer doors. But I can't feel a seam on the inside, and it seems like they are "cleanly" crimped around the door edges, not welded or sealed or anything. Does this look familiar to anyone? Should I try to pry them off to see what's underneath? The inside of the doors look clean and rust-free...strange...
Thanks all !!!
More to come...
Thanks all !!!
More to come...
