Need some brake pics
bigjhoov
nobody
Can some one post some pics of assembled 11" rear drum brakes with the self adjustors? I recently purchased some that weren't put together and need help figuring out spring placement and the self adjustors. Thanks.
raleigh_bronco
I know one of the vendors has a nice color picture in their catalog of a fully loaded drum setup. I just can't remember which vendor off the top of my head.
sprdv1
REBEL
Might not help, but I tried right. ;)
Baja71
Jerry, you're welcome to bring your parts by, or just come by, and take a look at mine. I have the '71 rear 9", so I'm pretty sure it's the small bearing, which in turn should make them 10" drums....but what the heck!!
How confusing was that?
bronko69er
EB Addict
Renton, WA
If my memory is right it should be set up the same as the 10" brakes (if you have those around to look at).
JWMcCrary
See if this helps.
bigjhoov
bigjhoov
nobody
I have that as well. need to know the color of the springs pictured.
Gummi Bear
Jer -
Snap a picture of your springs, post it up, and I'll label them for you. I didn't realize that's what was holding you up.
Give me a call when you get it posted.
bronko69er
EB Addict
Renton, WA
I think I know what you're asking and I think I know how to answer.
The shortest spring is the upper forward retracting spring, that one is easy to determine cause of its size. The other 2 are similar in size but the upper rear return spring should be noticably stiffer than the adjuster spring. At least thats what is in memory.
bigjhoov
bigjhoov
nobody
Got it figured out. Had to loosen my parking brake cable up so everything would line up. Thanks for the help.
