no mechanical knowledge!..can you replace the battery yourself? if so,go get a new battery,check the oil level in the motor,buy a 12 volt compressor to air up the tires,five gallons of fresh gas in the tank,a small battery charger,put the new battery in,hook the compressor up,air up the tires,check/top off the oil,pour the gas in,take the air cleaner off,pour a small amount of gas down the carb(SMALL AMOUNT)and crank it up,it will probaly start and die,pour a little more gas down the carb and repeat till it runs on its on,if this does not work after 3 or 4 tries call a wrecker....or find a local shop or ford dealer and talk to one of the techs,he may come after work to help you out....no all mechanics are bad
