New belt squeal.
KS.76Sport
Wichita, KS.
I replaced the alternator on my 76, while I was at it I replaced both alt and PS belts with gates belts. I went back with the same part numbers that came off of it. The alt belt squeals when I start it, and when I hit the gas at stops. I tightened it up tighter than I liked, and I could still turn the alt by the blades, it just doesn't seem to want to grip. I have shot WD on it, Ive adjusted tension looser and tighter, I cant get this bitch to stop squealing (no not the wife, the belt) ;), and its starting to irritate me.
Anyway, you guys think maybe the belt just needs to wear in? It is the factory pulley, do these wear out i.e. v channel get incorrect angles over time?
fordtrucksrule
Use some belt dressing it works every time for me well it used to now i don't need it anymore serptine setup
Dan74Bronc
Chandler, Az
toothpaste on the belt, works every time. Not the gel stuff but the more abrasive white colgate stuff. Maybe tighten the belt a bit too, if you can turn the alt pulley maybe it's too loose.
I gotta say though, I have my belts pretty darn tight and they don't squeel even without toothpaste. 10 years and my waterpump is just now getting loose in the bearings but it doesn't leak YET.
I take that back, on occasion my A/c pulley squeeks when I turn on the air , but only briefly as it engages the compressor.
blubuckaroo
Grease Monkey
Ridgefield WA
Is your new belt too narrow? Check the depth of the belt in the pulley grooves. If the belt is riding on the bottom of the groove, no amount of tightening will stop the slipping.
Greg_B
Cohutta, GA
Not sure if this applies but I installed a new belt on my serp setup a few weeks ago and it started squeaking on start up... drove me crazy. It was a new Gates belt... I took it off and put a Dayco belt from Autozone on it and now it is quiet as a mouse... Note to self... no more gates belts.
Greg
ransil
WD40 is a lubricant might stop the squealing noise but won't stop slipping that is causing the squealing.
make sure all pulley's are clean, and grease free. I always use simple green and a scrub brush
Rustytruck
Next time buy a goodyear gator back belt they are slightly wider. If sticking to gates belts buy the green stripe or green belts they a far superior to standard belts.
KS.76Sport
KS.76Sport
Wichita, KS.
The belt is even with the outside diameter of the pulley, so its not to narrow. I went and got some belt dressing last night. I re tightened the alt again, really tight this time. Didnt work, still squealing. I think there are three things that could be wrong. Either the altenator doesnt spin freely enough (Not broke in/defective?) the pulleys angles are shot or something is wrong with the belt itself. Good to know that others have had problems with Gates. I never have, always thought they were a pretty good product. Then again, in my opinion, most products quality control sux now days.
Greg_B
Cohutta, GA
I think I read where Gates was bought out by someoen else a fw years ago. not the same Gates they were a decade ago. Could be wring though.
Greg
d4xycrq
Boyertown
My daughter's Camaro requires extended cranking when starting from hot. It squeals each time this happens - I've always rationalised that the battery is demanding so many amps to recharge, for those few seconds after start, the belt is slipping on the alternator pulley. Belt dressing is only so affective. Never tried toothpaste!
