Belt Squeal - helppp
bsteab0yz
Hey everyone - would like some opinions on what could be going on with my setup. Just got a new alternator b/c the mechanic fried it when putting in a blueprint 302… the old alternator, to my knowledge, did not have any issues with squealing but the one before that did before it was replaced.
Brand new belt on the brand new alternator. The belt is a duralast 15405. It seems to fit well (see pic), but maybe rides a just a touch below the edge of the pulley.
You can see from the main pulley coming off the engine that it sits a good bit below the edge of the pulley.
Had the engine replaced and drove it for a few weeks and then belts started squeaking… took it back and had the belt tightened and drove it maybe 40 miles or so before it started squealing again. At first it was just on startup… now it’s pretty consistent until I get fast enough and then it’s quiet consistent chirps during the drive.
When I shift to reverse it was squeal for a few seconds, same thing for drive but a little longer. Then when put it park it seems to be the most aggressive.
Here is the power steering belt for good measure …
I believe all of the pulleys are original (‘74). Could it be time to replace them all? Or is there something more obvious happening?
Maybe they just aren’t tight enough because when I tighten them, it stops for a little while, but comes roaring back after time.
I unfortunately am not mechanically inclined but would like to get our mechanic some sort of option(s) to start with.
TIA
When it’s squealing, what does your ammeter say in the instrument cluster?
Does it seem to be charging excessively?
Next time you have the engine running, grab a voltmeter and put it on the battery and see what voltage reading you get.
Should be about 14 to 14 1/2, but excessive or insufficient could indicate other problems.
Even under normal circumstances, if the alternator is charging very weekly at idle, I won’t be recharging the battery and then when you rev the engine up, it tries to overcompensate. And that extra load will cause the squeal.
Did you by any chance upgrade to a more powerful alternator? Something more than say, 55A?
And I don’t suppose you still have the old alternator? I’m guessing not, but I wonder if the pulley got swapped over to the new one, or if the new one came with its own?
ransil
clean the pullies, no rust or old belt chunks.
don't put anything on them i.e. belt dressing that stuff never works
73azbronco
soap, as in bar of soap as dressing.
The pulley with the belt showing well below is probably the one making noise. Is it really worn, or is it really that much bigger? looks like that pully is either worn or different size.
Used to be a Goodyear “Gatorbacks” but it might be Gates now.
But I should add, they didn’t always work. It depended on what the issue was.
One potential cure is a larger diameter, alternator pulley with a deeper groove.
Came on some Ford passenger cars with big alternators I think.
With mine I was able to get rid of it for a couple of months at a time by cleaning the pulley grooves with carb cleaner and sandpaper.
I got rid of it permanently with dual belts.
Then serpentine set ups…
Bajabrewer
This is a copy & paste from another thread about alternator squeal - I still haven't gone explorer serp yet - It still doesn't squeal 6 months after this "fix"
I just went thru this with my 69-351w The belts needed alignment so I used some shims like these
https://www.ebay.com/itm/3943896744...d=link&campid=5335857059&toolid=20001&mkevt=1
I also installed a larger pulley on the alternator 3.25" instead of the 2.6" that came on it - larger diameter gives more surface area for the belt to grab.
https://www.ebay.com/itm/3044206208...d=link&campid=5335857059&toolid=20001&mkevt=1
Not sure which made more of a difference but with the belt super tight I only had it squeal once & that was when I got some water on it from washing the engine compartment. I do want to go with the Explorer serp set up but I'll wait & do that next winter when it will be off the road anyway. I also read somewhere that the Gatorback belts(pricey) made a difference but I didn't need to try them.
pcf_mark
I put a higher amperage alternator on my stock truck and the belt started squealed. Especially after start up when they battery had been drained a bit. I ended up going to a serpentine belt set up from an Explorer...
HoldMyPocket
Charlotte
Because the squealing happens all throughout the running period (doesn't just happen at start up but also while driving, shifting to reverse etc) I would speculate that it's not because the amount of draw from the alternator. That usually happens at start up until the vehicle warms up or so.
The way that belt sits in that groove is not right at all, it should ride up higher in the groove like the belt in front of it. I would look for the belt of equivalent length in the Gates brand.. I looked up the Duralast 15405 and it is is 40.5" long.. you'll be looking for Gates 7405 XL. 7 is the model/product series, the next 3 numbers are the size. 45.5" would be Gates 7455 XL for example.
Something else I noticed is the Duralast belt is a straight rib profile.. the Gates has a tapered edge, this could make all the difference. You can buy that belt on Amazon and take it to your mechanic.
B
bsteab0yz
@HoldMyPocket - the belt that is riding low is the one hooked up to the alternator... if this is changed to a larger one that sits up higher, won't that be far too big for the alternator? The alternator view has the belt riding just a touch low (maybe?) but seems to be the right fit. What is the solution to this - get a pulley for the alternator that will take the same belt? The alt pulley is 2.5 or 2.75" in diameter.
@DirtDonk - Of note, it is a 72 Amp Alternator with a 2.5 or 2.75" diameter pulley (can't quite tell). On start up the ammeter stays pretty much steady on zero. Granted, maybe it doesn't work, lol but it does have some movement every now and then. But, I start it up once a day or so, so not that much battery should be drained due to it sitting too long.
Ammeter is not working, or the alternator is not.
Is this original wiring, or a re-wire with an aftermarket harness?
The ammeter will shuffle a bit to the negative when you turn things like the headlights and radio and heater on. And heavily to the negative when the starter is cranking. But it should immediately go positive after firing up the engine.
What you're watching with the ammeter is the system/battery being drained (negative) when the alternator is off, and the system being powered and the battery re-charged when the engine is running.
It's not uncommon to see the ammeter go to 30, 40, or even 50 amps positive right after startup for a few moments. It then gradually comes down to near zero (just a bit positive) when the battery is fully charged and being "maintained" by the alternator.
Hence my mention (I think?) of putting a volt-meter on the battery when the engine is running. If you do not see at least 13.5 to 14 volts, your charging system is not functioning properly.
A 50 year old ammeter is allowed to fail of course, and a re-wire often involves bypassing the ammeter in the dash and having the alternator charge the battery directly. So it's certainly a possibility your gauge is kaput. So a hand-held volt-meter on the battery is a good thing.
What about the pulley? Is this the same pulley that's been on the Bronco since you bought it? Was it changed at some point?
I don't remember how the stock ones encompassed the belt, but having one pulley with the belt set deep into the sheave/groove, while the other is riding near the top, does seem a bit out of place.
But for all I know, that's how they were from the factory. I never had any of these problems until I started changing things from stock. And it's been long enough now that I don't remember some of the more mundane details.
As HoldMyPocket metioned, the fact that the squealing is going on all the time kind of disputes the alternator charging only theory.
Other factors that cause squealing have already been mentioned, but again, they are:
1. Glazed pulley grooves.
2. Misaligned pullies.
3. Incorrectly sized belt/pulley combo
4. Too loose adjustment (not likely here, but it's a thing).
5. A load elsewhere, such as a failing power steering pump, or water pump.
6. A glazed or worn belt.
Cleaning the pulleys and checking the other things should help narrow it down.
In the meantime, got a better overall picture of your alternator? Is it a high-output small case 1G, or perhaps a converted GM type?
Reason I'm asking, is that 72a is kind of an odd number for a Ford-based alternator. But fairly common for GM stuff.
If not pic, maybe just a part number? Or I suppose, if it did not require any changing of the original wiring, then it's probably just a Ford-based unit that's been enhanced for a few more amps. Been awhile since I looked, so maybe 72 is now a common option.
gr8scott
Here's how mine ride in my water pump pulley. It's what came with my Bronco and I'm assuming its a stock pulley.
That’s basically how I remember mine too.
Although it’s also possible to have had the belts changed over the years with the wrong pitch/width.
However, what you have looks correct to my eyes.
@DirtDonk - this is the alternator that I have.
GM 10si based alternator.
That’s why the “72” sounded familiar.
Not even a Ford unit, so would easily explain the difference depths between the pulleys.
Although I’m sure there is some standardization between brands, there are also plenty of mismatches.
Not sure what pulley would work best, but I can pretty much guarantee there are a lot of choices for a GM alternator.
Maybe even the same ones that fit Fords?
HoldMyPocket
Charlotte
This pulley should work: https://www.cvfracing.com/ford-alternator-pulley-sbf-fe/
I just finished learning a ton about v-belts and pulleys when I completed my Vintage Air installation on my 78 F150 4x4.. CVF was a god send of customer/technical support. You could probably summarize your post in an email to them and they will be able to confirm the best approach before making any purchases. They may want some pictures from further away to show all the pulleys/alignment/etc.
Additionally, I used that pulley on a GM 1-wire alternator which i then swapped out for a Ford 3G alternator. It will work on either.
B
bsteab0yz
@DirtDonk - is there is "favorite" or best Ford alternator that most use? All other pulleys appear to be from the original set up. Just curious if there is one that is more compatible with an original set up?
