You would think that they would reconfigure the tooling that they use but I guess if people are snatching items up the way they are they are not really in a rush to fix it. I would spend double to have quality metal for a tub. It would save us time and undoubtedly the consumer in the end.Great job guys!!! What a lot of work to get it all lined up. Great attention to the little details. You think Dynacorn would have better control of their tolerances.
The jig is most definitely priceless!!How much for the Jig???
Seriously though, is the full metal body that I've seen on bronco
sites that bad?
Carpenters tubs do not come with doors, fenders, hood, grille etc. setup on the tub. The most time consuming work is getting these parts installed on the tub properly for proper alignment and function. Putting a tub together is the easy part but making everything work and look like ours does is where the hours come in.Like OX says how does cost and fit compared to the tub Carpenter is seling for around 9k?
Nice work!!!!!!!!!
I spent 4 months aligning my doors and they are only about 90% spot on. If I got to 100% like this bronco I don't think I would drive it for fear of messing it up perfection.
You can give me a call at the office and I can go over things a lot more with you and also give you measurements you might need with pictures. There is just a lot more to building these tubs than measurements.Guess you don't want to share the specs/dimensions on the jig ? I am beginning to piece a new tub together myself as finding a good tub in the NE is impossible.Just so I can confirm my measurements.
WOW ... That's some fine metal work !! Did you try to fit a hardtop on it ??
just wondering about add man-hours needed !?
The stock body is a lot better as far as panel fitment and door alignment than the aftermarket parts. If we have stock panels on a Bronco that we are restoring and we can salvage original parts I will use a stock set way before I put a new set on. The door gap and body lines have been off on everyone set of aftermarket doors I have ever used. If I bolt an original door up to the same body it is 10x closer than aftermarket. So the answer to this is yes originally the Broncos were not perfect but are leaps and bounds ahead of the recreations.OK, was door alignment really that good when these things were new? It seems to me these things were not built spot on from the factory (can take two seemingly unmolested factory fenders and neither one fits the same as the other).
I can see a market for a perfect bronco body, but I kind of have to wonder why you would start with a stocker for the jig that may have not been built that great to begin with. Was the jig modified after initial build.
We built the Jig before we started this tub and we have about 200hrs in building the jig alone. The body time is separate.How many of those 300 hrs went into just building the jig?
Yes, I will email pictures over to you tomorrow.ps...im assembling a bed from scratch...any chance I could get some photos of the striker posts and tail light post? I'd like to see how you guys fit your inner quarter to those areas a little better than what you have posted.
email ryanscottwilliams@hotmail.com or send them to my phone 616-617-7984
