new distributor installation - HELP
694play
I am installing new MSD ignition and I am curious about the orientation of the distributor. When I pulled the old distributor out I noted the location of the rotor and put the new one back in the same way but the distributor housing can be rotated in any direction and still locate the rotor the same. Doesn't the housing movement cause the pickup location to change just as you would adjust the timing? Since the new distributor does not have a vacuum housing it could be 180 out right?? what would this do upon start up. (almost ready for this part)
Am I totaly off base or just partially off base??
ken75ranger
Troy, NY
As long as the rotor is pointed in the same spot as the old one your ok. You just need to put the plug wires on the same way as the old distributor and set your timing. The only way it could be 180 out is if you turned the motor over with the distributor removed. If you did turn the motor without the distributor in pull the valve cover and turn the engine while watching the valves for #1 cylinder. If they are both closed while the piston comes up it's the compression stroke. If the exhaust valve stays open go around again.
Madgyver
Bronco Madman
If you lose the original markings then is the way to start over
This is what I always do.
  • Make sure engine has new oil and oil filter in it.
  • Prime engine oil using an oil priming tool or a gutted distributor and a drill. To use an old dizzy just remove the inners and the cam gear.
  • Make sure there is oil pressure.
  • Remove #1 spark plug.
  • Using a starter switch on the solenoid, jog engine over while priming the oil pump a couple of times.
  • Now place your finger close to the #1 spark plug hole and jog engine over. You will feel air pushing out the hole on every other stroke.This is the compression stroke and where you what to start as your baseline.
  • Find the compression stroke and look at the timing marks. Use a breakerbar and socket on the crank bolt to line the marks up about 8-10 degrees BTDC on the compression stroke.
  • Your distributor cap should be all wired up with your plug wires. If not, set it up where you want the #1 plug to start. Fit cap on the dizzy and mark position of the #1 plug on the dist. bottom half.
  • Now drop that dizzy in while trying to land the rotor pointing in the area of the #1 mark you made. You may need to use the oil pump priming tool or gutted dizzy to turn the oil pump shaft for the new dizzy to drop in where you want it.
  • Now you got the dizzy in. Line up #1 mark and rotor. Double check crank timing marks, it should be at 8-10 degree BTDC on the compression stroke. Reinstall #1 spark plug and wire, Lock down dizzy.
  • Add fuel, make sure trans is in park, parking brake on, timing light ready, fire exstinguisher close by and charged. Wire up everything like you should and start engine. This baseline position with crank and dizzy will get motor started, if not, then you have other problems
  • This is what I always do...........
    Good Luck,
    madgyver
694play
694play
Thanks for the input. For some reason I just had this vision of pistons shooting up through the hood but I hooked it all back up, cranked it up and set the timing and went wheelin the next day. Ran great.
