New Front Coils!?
matt w
I just replaced the rear leaf springs on my 73. They were way ready. Here are pics of my front coils. They are about 11 years old now. Does they way they sit look normal for a 3.5 lift OR should I change these out as well!? It seems as if the front end bottoms out over mild whoops at under 25-30 mph. Also notice how the coil on the drivers side does not stack straight like the other. Why would that be? New coils are not all that expensive. What’s your .02 cents!?
Thanks for the input and advice!
Matt W.
74 Bronco Billy
Worn out, way to easily compressed. Replace, and if the cups show metal fatigue you may want to replace them as well. Mig's custom cups on this site has real nice ones.
Sent from my SAMSUNG-SM-G930A using Tapatalk
matt w
matt w
I’m wondering what NEW 3.5 coils look when sitting under normal
Load!?
75MIKE
NE Washington
What brand of coils are those? Never seen anything like it, no wonder you are bottoming out. There needs to be a gap between the coils to work as designed.
Rustytruck
when raising the rig did you get an adjustable trac bar to recenter the axle? the little offset may be why the springs look the way the do.
Have you measured between the frame and the axle to see how much lift you still have in those springs. Have you measured the rear axle to the frame to see how much lift the new rear springs gave you?
yakelys69
Load!?
This is what mine look like, they are linear not progressive.
JBG Super Flex Coil Springs, 3 1/2, CSH05 (deaver) but not sure deaver still makes them, I can't find them on the deaver site anymore.
Yours appear to be a worn out progressive design.
matt w
matt w
I’m not ratting 🐀 on any vendor! Ha
matt w
matt w
The front end has not been touched.
All I did was install the new rear leaves.
I have not measured a thing...yet.
Basically it seems as if everyone agrees that I got my 11 years worth of $$ out of these 3.5’s.
Now I need to decide if I should move away from a progressive spring since these have seen better days.
WILDHORSES
USA
Hi Matt, possible issue with the bottoming out is you have a limited down stroke on the front shock with them in the stock position. It would be very unusual for the spring to bottom before that shock but who knows. Do you think you are hitting the bump stops?
Here's one thing to note about "coil bind" if you really slam the coil it's going to bend and get really out of shape. I don't mean a little coil spring bow like your pic but really out of shape and very noticeable.
Ideally you would want to set up a bump stop to control the down travel before the shock or coil bottoms out.
Recommended parts
1. Pair of coils
2. New shock towers for longer travel shock
3. Pair of Bilsteins
4. Bump stops custom set up for your rig
Jim
matt w
matt w
Recommended parts
1. Pair of coils
Jim
Thank you Jim,
I have the stock bump stops on the front of my 73’.
Do you even offer a front bump stop for a 73’?
I would have added a set years ago but could not find them.
I have some shocks that are not all that old so I’m not going to spend $ for those for a bit as I’m not seeing that as an issue.
Thanks again.
WILDHORSES
USA
Thank you Jim,
Thanks again.
Here's link like to the bumps. https://www.wildhorses4x4.com/category/Bump_Stops They are generic urethane but will bolt to the 73 D44. With the stock shock mounts I would run the #1539 4.5" bumps.
Jim
74 Bronco Billy
Or make your own lifts and use stock bumps.
WILDHORSES
USA
There is no chance the shock is holding the front spring that compressed is there?
99% no chance. There would be zero up travel if that were the case you would totally feel it and know the shocks needed changing.
Jim
broncnaz
Id say your coils look pretty normal for progessive springs. New ones may be the same as Ive seen several broncos with new progressive coils and they are that way. Id do some measuring first but like you said coils are fairly cheap and easy to replace so new ones wont hurt. While I'm sure coils do say over time its rare to see them sag all that much. If they did the 47 year old stock coils on my 71 should be pancaked/
savage
Bronco Nut
Renton
I have a 3.5 inch progressive coils and they are not that close together.
