new guy, '77 build starting
Scubadds
Last night, I snagged a '77 Bronco that is midway under the knife....It had been sitting in the body shop I have used for a few years now. Guy finally decided to sell.
Best I can tell, is he drove the red truck into the shop to rebuild it.
Presently, it has new doors "in the black", new metal in a few areas; some in primer and the right rear quarter needs to be sanded and its ready for primer. It is back to Uncut now...
It is mocked up and the bare frame, sitting on James Duff 3" body and 5" suspension lift. Previous owner had planned a uncut on 35's build.
It comes with new wiring harness, dash off his old parts '74 that is radio uncut.
Tons of new parts, new fiberglass hood. Original motor that is ready to go. Transfer case has been rebuilt. C4 needs to be gone thru.
I bought it very quickly as my body guy that I trust has been working on it and said its good to go. So, I have not dug thru the parts pile yet....but its has a lot of parts that are new or spares off his '74. (including the second motor)
My first decision that I need some guidance is getting the lift back down.
I can't just remove the 3" body lift, as the hoops for existing suspension would hit the inner fender.
My thoughts would be around a 3" lift? My next decision, that I see asked before, but I have not really gotten a true flavor of the difference is....
Whether to cut of not???
I came from a Defender 110 and D90 with 35's...I did not like the 35's but this Bronco has 4.887 gears with True trac.
So I need to regear I would imagine?
So, should I consider going back to full original??? I honestly am not drawn to the look of the little tires, or is there an accepted lift and tire combo that retains the flavor with out cutting?
I am drawn to the look of the mild cut and fender combo (some are painted white, and look factory to my untrained eye....
I just need some opinions to get me pointed in the right direction...
Is there more value in an original Burnt Orange truck that looks factory or a cut and lifted restomod? or is there no rules to follow (it seems like in the classic car world, the old numbers matching cars only really matter when its a rare care; and the restomods are bringing as much money)
Not that the resale is my primary goal; I just spent a ton on my d90 and when I sold it, I think I could have stayed stock and gotten more money)
duffymahoney
Congrats! I also have a 77. It's a fun year, with a few differences. I'm in the middle of a frame off. You seem to have a huge question in your mind. To return it to stockish or run larger tires. LUBR or lifted uncut broncos look great with 32x10ish tires or even 34x10ish tires.
If I was you I would ditch the 3" body lift, they always look goofy. Worst case scenario is you have to change shock hoops, which wouldn't be terrible. I would run 1" body lift and a 2.5-3.5" suspension lift.
Here is a great link to a bunch of LUBRs
http://classicbroncos.com/forums/showthread.php?t=178183
Hope it helps and welcome to the bronco world. Post some pictures of your ride!
S
Scubadds
thanks!
That's just what I needed, I had googled it; but didn't find the motherload of pics.
And most pics, didn't give any details of height etc
67RT
Maybe post it here as a project to trade for someone who has an uncut low riding cruiser that wants to turn it into a beast. Why undo all of that work?
S
Scubadds
Presently it is just mocked up; I think I can uninstall it now without too much trouble...
I spoke with the vendor and there is a possibility of exchanging the parts for a lower lift.
But I would have to do some grinding and cutting in a few spots; but its not painted and now is the time to do it....
Rox Crusher
I would keep the 4:88 gears and use a 4r70w overdrive trans instead of the C4 it came with
S
Scubadds
Thanks, can you spoon feed me on this one?
I see some old threads, need a controller for trans? etc....
What would that accomplish?
My trans is not in good shape anyway....
duffymahoney
Lots are involved in the swap.
To control it you either have to have a trans controller or swap in a later model explorer 5.0.
You have to get new drive shafts, modify crossmember, and get a adapter to the transfer case. If you want overdrive, this is a great transmission. If you go 32-33" tire 4.88 gearing might work but I would have to do some math. I have 4.11 on my 4r70w and my tires are just under 33". Which will put me pretty low on the rpms for highway speeds, some people claims it will cruise all day long at 70 with these gears and tire size. Only time will tell:)
S
Scubadds
Its not out of the realm of possibility to do that swap;
Just gets to be a bit much to digest as I am only in the first 2 days of research....
I am trying to sort out the lift first....
I am trying to decide if I should get 3.5 SL as I already have the Trac bars installed that require at least 3" of lift. Then I could add or not add a 1", if I go 35s or 33s
