I've been saving some parts for a while, and when I see a deal, I jump on it. I've found that I never have time AND money, always one or the other, so when I have $$ I buy parts so when I'm strapped, I still have something to do, or something to sell. My OT got cut, I work in mining and am lucky to still have work, so this will be a budget build.
The motor:
The master plan is to find a nice explorer motor, get a new cam, reseal it, run it with the mustang efi, ign, and preferably the sploder serp stuff. But for now I'll run the mustang motor to get the bugs worked out.
Its SEFI, and good running. I don't see anything on the car that has been modified. It was either a babied 197k or a run hard 97k. It had a lifter tick after sitting for 2 days, and smoked a little, but the comp checked out good, a wet test only picked up 10% compression, so I yanked it, pressure washed it, and will drop it in with new oil and plugs.
Tranny:
I'll put some time and money into the trans, as it will be permanent. The seller said that sometimes it hunted between 3rd and 4th on the highway. I have never rebuilt an AT, and wouldn't be able to identify bad parts, so I wanted to identify any symptoms and research how to deal with them, before I cracked pandoras box open. The donor car has wasted tires, has the temp spare on it, and came with a dismounted tire in the trunk. I mounted it up, and roadtested it. I got up to 70 mph, no hunted, slipping, anything to indicate any problems at all. I did find that roadtesting $250 5.0 mustangs on dirt roads in the rain is incredibly rewarding, after owning 3 mustangs, creeping over speed bumps, stopping short to not hit parking curbs, this was a nice change
I ran into my neighbors/cousin inlaws heading into the desert on quads, wanting to see some donuts. The last donut left me nosed down in the ditch, high centered, spinning baldys on the dirt trying to back up. I'm in a $250 car, so I slam it in drive, mash the gas and cut it hard, riding the ditch for a good 300' till I had the speed to climb out, full spunoutinthegrassnotgonnagetlappednascarstyle. The inlaws and I were quite impressed.
I bought the $20 autozone "how to rebuild ford automatics" book and got to it. I dropped the exhaust and hooked up a borrowed pressure gauge, and the pressures checked out against the book specs. The case had some yellow marker on it, I was thinking JY trans, but the last half of the VIN is stamped into the case, so I figured it had been out of the car for a rebuild at some point. The pan was surprisingly clean. I didn't have a slide hammer to remove the pump, so I bolted a piece of chain to the puller hole and gave it a couple of yanks, worked fine for me. The seals on the pistons were fresh, the 2-3 accumulator piston was an updated part, and the intermediate clutches still have the branding printed on the wear face, so this tranny is fresh;D
My searching says the 3-4 hunting is likely due to misadjusted TV cable, causing low line pressures, which can cause the direct clutches to go out, which will cause serious 3-4 hunting, and eventually loss of 4th and then 3rd. I will disassemble the direct clutches and check for excessive wear. At this point I will need the "ring seal kit" for the tailshaft, I may be able to take them off of the car shaft, but not so sure it worth it, I need the extension housing gasket and seal, upper valve body gasket and some D20 seals. I also want to get a shift kit while I have the valve body out. I talked to a builder at the supply house, he told me that the OD servo pistons are lettered, like A-D, As and Bs give higher OD apply pressures and Cs and Ds are softer and will burn up the OD band. This stuff is starting to make sense to me. Tomorrow I will be cleaning, inspecting and ordering AT parts.
Misc:
I will use as much of this car as I can. I need to research throttle and TV cables, VSS with speedo cable, and find a reverse flex fan. It may be worth looking into a good electric fan, I'll have to chew on that. I think I have a PS hose laying around that will work. The EB has headers, I'm not sure if I should just weld O2 bungs in them, or try to fit the mustang headers. I need to eliminate the EGR and air pump stuff from the engine. I made an egr block off plate at work, and will probably pick up the fordfuelinjection.com EGR eliminator, or build one myself. I have twin fuel tanks, and really don't want to put inline pumps, accumulator tanks, etc etc in this. My 71 EB has a healthy efi 351 fed off of an inline pump alone (E2000?), I may go that route, but need to check the reliability of it. I'm thinking that possibly the easiest/cheapest/reliablest setup may be to modify the rear tank to use the mustang pump (scab the top of the mustang tank on to the EB tank if I have to), run the pressure and return lines from this tank, and use a low pressure pump (I have one) on a toggle switch to feed the fuel from the front tank into the rear tank. Lots of later model GMs are set up like this.
