rockingm82
Just installed a new master cylinder.
Bench bled the master cylinder to a no bubble state.
Ran new brake lines from the master cylinder to the proportioning valve.
Bleeding the lines and it is going really slow. Just get a trickle of old brake fluid when opening the rear wheel's valve. The brake fluid is clear not then red that has been installed.
Do we just keep at it or is something wrong?
-Novice mechanic.
-Novice mechanic.
