New Member with Qs?
gettyup
Colorado
Hello all.
I'm a new member here. The site is great!
I have some questions on some proposed rear end work that I was hoping to get some input on.
Here are my plans for the rear end. I have a full width 60 (low pinion F250) to put in the rear. Was planning on extending the wheelbase of my '77 in back about 3"-4". I plan to use coil over shocks with extended factory radius arms attached with factory-type "C" bushings over factory-type axle wedges. I plan to add a wishbone-type 3rd link.
My questions are:
1) I have plenty of factory 1/2-ton Ford & Bronco radius arms laying around & was planning on just extending them 10-12 inches. I've seen many methods used to extend them. One method which looks particularly interesting & simple/cheap/effective are the extensions on this website: http://www.bentandtwisted.com/catalog/ Anyone have experience with these???? Or, is there an easier recommended method?
2) I'm guessig that I'll probably run into a gas tank clearance problem since I'm moving the rear end back. I'd like to eventually have a large capacity rear tank & was thinking of just notching it out/rewelding it to clear the rear end. Has anyone else run into this problem & is there a simple solution???
Regards.
SaddleUp
Vancouver, WA
A few questions in return.
Why are you reducing the articulation? If your purpose for going to the coil rear suspension with radius arms is to gain articulation then you will be unhappy with the result. (The rear leaf springs already have more articulation than the front coils) The only way coils will provide more in the back is to go to a coilover shock with a 4 link setup.
Why are you decreasing the ground clearance? The Dana 60 will reduce ground clearance in the back.
Why are you going to run weaker gears? The 9" Ford already has stronger gears than a Dana 60. With 31 Spline Alloy axles it will have stronger gears and axles and be in a smaller package. With a bit more money 35 Spline alloy axles will be a lot stronger than stock Dana 60 axles.
As to your questions I haven't used either setup however there are others that have done both.
md_lucky_13
Idaho
I have to agree 100% with saddleup..
The 9" Ford axle is one of the greatest axles you could come across. It is practicly the Chevy 350ci of the axle world. Parts are cheap. They are everywhere. And they can be built to handle anything you would want under an EB..
For extending the wheel base, there has been a lot of talk about it. Many people have notched the rear cross-member, and a couple have even notched the gas tank..
In my experience and opinion, it is not worth the time, energy, and fabrication to do either of those options. I would run the coil-overs in the back, with a full 4-link, not a 3, using tractor/offroad adjustable heim joints. I would push the axle back a full 9-12".. Build/buy a fuel cell, and put it in the back, out of harms way. This will save countless time and energy.
Do you also have a full-width front end? If not, sell that 60 rear and upgrade your front end.. If you need more then a dana 44 up front, I would look into finding a dana 60 front end, and cutting it down to EB size. They make all the parts/knuckles you need to do this, and it should't cost much to have a machine shop take care of it if you gut the axle down to just the tube before hand (we shortened a few Dana 44s on a jeep cj-5 many years back, and they didn't charge but $100 for the whole deal)..
We actually did a jeep flat-fender, doing EXACTLY what you are describing. We took Ford style radius arms and attatched them to Scout Dana 44 axles. The guy used coil springs instead of coil-overs, but did exactly what you are taking about, everything else considered..
He was a little depressed when my rear leaf springs out-flexed his setup.. The Ford radius arms may be CONVIENENT, but that doesn't make them right for your application.
broncorckcrwlr
London, Ky
I stretched my wheelbase to 106 inches by extendig the frame and moving the leafs back. It was well worth the effort and $$$. I also agree about the 9 inch. The only reason I can see going to a dana 60 rear is if you are going full width in front and don't want to but another rear since you have one. I'm building a dana 60 for the front and already have a full width 9 for the rear. Good luck with your mods.
G
gettyup
Colorado
Thanks for the replies thus far.
I guesss I need to re-explain my plans & situation.
I am well aware of the stoutness of the Ford 9". I have the reinforced '77 housing as well. I've built two different 9" rear ends for projects in the past & they are great units. My plans are to go full width & I happen to have a D60 pickup rear end already. If I already had a 9" full width I'd probably use it instead. I don't feel the D60 is anything to shy away from though, especially if I already have one.
I plan to push the rear end back to have darn near a 90 degree departure angle, which I couldn't do with rear leaves. So, the plan is to use coil overs in the rear. I also have a line on a reverse cut D60 full width front, but that's a different topic.
I like the factory radius arms & have a dozen of them to choose from. This is why I'd like to extend & use them on all four corners. With extended factory arms, Ive seen EB's with an amazing amount of front flex. I checked out an early Bronc in Moab just last week with James Duff longer arms. The front performed awesome! A bit more flex than the rear Wild Horses leaves it had. I though I'd mimic a similar setup, front and rear. I dont see where the extra work involved with a new four link setup would have been any better than what I observed. He already had too much artuculation, actually. A new four link certainly looks like more work to me for not much more yield? The third link I plan to use for the rear would be a parallel, same length triangular "wishbone" link from the frame rails to the center section.
Thanks.
SaddleUp
Vancouver, WA
Thanks.
Even though it didn't look like it I would almost be willing to lay down money on the rear leaves having more flex than the front ones even with the Duff's extended arms unless the shocks or something were holding the rear leaves back. Even with the strength factor removed a shaved 9" will give at least 2" (probably more) extra clearance under the axle. To me the clearance underneith was even more important than the departure angle but it will depend some on what you intend to do with it.
G
gettyup
Colorado
I appreciate the constructive criticism, but I'm not looking for anyone's specific approval on how to build my Bronc. Nor am I looking to debate or bet anyone money on the flex of coil overs vs. leaf springs. There's nothing wrong with a rear 9" with leaves. My old '76 F100 has it. I built the same thing for the rear of my CJ5 and it's wonderful too. My goal is to have close to 90 degree approach and departure angles with 38" - 39" tires. I simply can't do that with leaves in the rear. The rear will be pushed back too much for leaves to work & the front will be pushed forward.
I simply had questions about extending factory radius arms & how to handle gas tank/rear diff clearance issues.
There also may be front track bar & drag link issues with pushing the front end forward. Has anyone moved their front axle forward? How many inches forward can you get away with while leaving the steering box where it is?
Regards.
Jeepincj7
Lake Elsinore, CA
4" forward is about the max without a lot of fab work with the steering box location. Here is a good write-up on it with a Toyota box in the stock location:
http://www.broncoholics.com/support/topic.asp?TOPIC_ID=1263&SearchTerms=Shane
I will be moving mine forward 4" after the middle of June, but I run a 79' F150 4x4 box moved back on the frame 6" with the pitman arm forward.
BTW, I think what everyone is trying to tell you is that the stock radius arms(even extended stock arms) will not flex better than a four linked setup. If you are going to run coilovers, then I would do the four link. Just my opinion though considering the amount of fab work involved anyway. Its the better setup.
Also, I seriously doubt that you will be able to retain anything in the way of a tank in back of the axle with a zero degree departure angle. You might be able to recess a small 12 gallon tank into the bed of the tub, but even that will be a stretch. For sure you will be gutting the current crossmember out.
In June my plan is to move the front axle forward 4" and move the rear axle back 6" and keep the leaf springs. Its a simple design and it works for me and what I need. There is room on the frame to do this as well. This should leave me with very good approach and departure angles in the front and rear. I will be recessing a 20 gallon fuel cell into the tub just above the frame rails but will keep my current 9".
md_lucky_13
Idaho
I won't try to convince you to do anything further. It is your ride..
For the rear, we went back 10". That put the very back of the tires at almost the end of the tailgate. But, this causes 2 problems:
1, when you go to extend your inner fenders, they are going to end up against the tail-gate. This leaves 2 options: try to box them in, so when you open the tail gate you will be looking at a flat steel wall, pressing up against it. Or, you could extend them back and connect them to the tailgate. We did this, which made so the tailgate had to be shortened. It took a lot more work, but in the end, was worth it for the results.
Up front, you only have a couple of inches before it starts to interfere with steering, tracbar placement, and other issues. We went forward 2 inches, worked well. You might be able to go more, but if you do a 3 link, you still have to deal with tracbar issues. A 4 link might be able to be built to prevent this, but then you run into clearance issues with it and the oil pan. From what we saw, 2 inches was the best option..
I have tons and tons of pictures on my website of the stretch, and can answer any questions.
md_lucky_13
Idaho
That is one more thing I forgot..
Having any fuel tank in the stock location is going to be out of the question. There is no room. You will have to use a fuelcell in the back, or find another spot. We went under the passanger rear seat.. I don't think, even with notching, cutting, dimpling; anything. You won't be able to do it.
G
gettyup
Colorado
Thanks jeepincj7 & md_lucky.
That's exactly the info I was looking for. I really appreciate it.
G
gettyup
Colorado
Hey md_lucky-13,
I was just looking at your photo album. Great pics! Kinda soggy in Moab this year, wasn't it?
You're buddy's Yellow bronc (Gary) looks to have an extended wheelbase & coilover shocks on the front at least. Is Gary a member on this site too?
His departure angle looks great & is about what I'm looking for. Any more info on this yellow Bronc?
SaddleUp
Vancouver, WA
Regards.
Like md_lucky_13 said, it's your ride. I wish you luck and hope it turns out better than I suspect.
md_lucky_13
Idaho
Nope, Gary isn't a member of this site..
He is not really into computers.. In fact, the first computer he ever touched was a lap-top he bought, very old and very used, so he could program his new EFI..
But, he is my step-dad. I worked along side him on that Bronco through most of it. I pretty much know it in and out like he does. He could give better exact details, but I can let you know pretty much anything you would like to know..
The front is coil-over, and the rear is 1/4 eliptic.
Moab was SOAKING this year. There is nothing like driving 15 1/2 hours from North Idaho to be SNOWED ON in a desert.. I couldn't beleive it.
I just got a bunch of videos from our trip. I need to find a way to reduce quality, or at least zip them up, and see if I can host them on angel fire... Hopefully it will work.
G
gettyup
Colorado
Thanks Mike.
As I get a bit further on with the build, I may a question or two. At that time, would it be possible to get more info from Gary about his Bronc?
We've been going to the Moab EJS for about 15 years now. There's something about Easter weekend & rain or snow. Seems about every other year it's a soggy one.
Thanks for your help.
md_lucky_13
Idaho
I dunno..
It seemed like the past few years of EJS havn't been that bad. Last year it rained a little bit, but nothing too bad.. We are always leaving from North Idaho, so it feels really nice this time of year to hit the weather when it is high 60 or so.. Maybe we just have been spoiled into remembering it was good weather. This was our 6th year going, and will be a family tradition for as long as we are able.
If you have any questions at all along the way, feel free to ask. Like I said, I worked with him throughout most of the project, so I should be able to answer any questions. If I can't answer them, I can sure make a phone call! ;D
