Ditto, whats a going rate for body only paint, minimal dings?What is a Bronco paint job run at Beach City Broncos?
Can we get a group discount? I have a couple in waiting too.Ditto, whats a going rate for body only paint, minimal dings?
I think you answered my question. I don't have Raptor Lining though. I have Rhinolining (tinted) sprayed on the outside of my fiberglass body. It is smooth enough it doesn't catch lint off microfiber towels or really a fingernail. It has good adhesion, and there is apparently no way to remove rhinolining from fiberglass because of the gelcoat and such. I just want to change the color. It currently has a green metallic top color (with UV protected tint/topcoat) applied by Rhinolining dealer back in 2001. I don't want to add any thickness. I just want to change the color and dull it down a bit because it looks like too much sparkles in the sun.To paint raptor liner; Any existing coating must have good adhesion to the body or it will have to be removed. Then eveything must be scuffed and cleaned thoroughly. The raptor liner is standard in black or "tintable". The paint (without binder so it is concentrated) is added to the epoxy and is sprayed. Everything must be flat without dents or they will show. Itusually takes 1 raptor kit to do the floor or 2 kits if you are doing the entire inside. We typically use it on the underside if we are doing a "frame off".
