Benzo
I was thinking about changing my cam and putting in one I like much better. The only thing is I don't know if it is a good idea to swap in a new cam with a well used engine. I actually do not know how many miles are on this engine, but it runs sweet and it sure loves gas. I know the main bearings are pretty worn because I have 15lbs. oil pressure with the engine idling at 180 degrees. When the engine is at a cold idle, I have 60 lbs. of oil pressure. I am still thinking about what kind of engine to build and I want to play in the mean time. I just do not like the stock cam and I was planning on changing the timing chain. To tell you the truth, I was just going to change the timing chain and then I started thinking.... Hmm the front of the engine will be opened up. You know, just staring at you and I want a differnet cam anyway. After that it's time, gaskets, and adjustments. Yes I am hooked. What do you think about the swap?
