New Power Steering Conversion
Tuck73
Just installed Borgenson Power power steering conversion. Turned whelk back and forth to remove air and filled tank back up. When I started the Bronco the steering wheel statutes spinning uncontrollably. Has anyone ever had this happen? What did I do wrong!
You got the pressure and the return lines swapped.
Pressure is closer to the sector shaft.
Return is closer to the steering wheel.
And yes, did this before.
T
Tuck73
There are two separate fittings that are different sizes. We attached them based on which fitting fit where. Is it posse they got the fittings backwards at the factory?
T
Tuck73
Thanks! Checking today. Trying to get it on the road today. It’s been a year long restoration This is one of the last things to get fixed.
T
Tuck73
That worked! Thanks! Now if I could just keep the driveshaft from hitting my headers, I would be golden!
