New Rear Drum Problem
BoureeOne
Madisonville, La
Tell me what is wrong here. This is the WH rear drum brake kit. The shoes are part # 3118. I have a 1966 wagon, small baring, 10" drums. The shoes are 2 1/2 " wide. The pin to put the retainer springs on the shoes are 2" long. Either these are the wrong shoes, or the wrong pins got put in the kit. I don't have enough room the connect the bottom cup of the spring, let alone go all the way through the spring and top retainer. Any help would be appreciated.
Scott
Major Tom
brakes
I just did a brake job on my 1966 u13 .I ordered the brakes through Rock Auto along with all new hardware. I had the same problem with the spring retainer pin being too short I ended up cleaning the old pins up and used the new springs. You are correct on the size 10x 2.5 on the rear and 11x2 on the front
BoureeOne
BoureeOne
Madisonville, La
Here is the how short the pin is. When I call O'Reilly's, they tell me their pads are 1 7/8" inches wide. So trying to confirm, is the pin too short, or pads too wide.
Hozr
Rogue Valley, OR
I had all sorts of incorrect parts in my drum rebuild kits. I had to reuse the old pins and one of the adjusters due to mis packaging....multiple times.
BoureeOne
BoureeOne
Madisonville, La
Well you guys were right, it was the pins. Here is the difference between the original pin and the pin in the kit. I had to go to O'Reilly's and they just let me go through spring kits on the shelf until I found a kit with pins long enough. Brakes are now together. Hope I did them right.
redwards69
Double Oak, TX
Working on my rear drums now. Hope mine look as good as yours when I'm done! btwv what size are the blocks under your jack stand?
BoureeOne
BoureeOne
Madisonville, La
Those are actually the remnants of garage header boards that I grabbed at a house that was being built in my neighborhood.
This is the first time that I have ever done drum brakes in my life. Attached is the thread where I asked for diagrams. It helped me a lot. Remember, there are several parts that you must retain from when you take your breaks apart.
http://classicbroncos.com/forums/showthread.php?t=250342
BoureeOne
BoureeOne
Madisonville, La
I noticed in your pics that you have your u-bolt/spring plates upside down. The beveled edge should go against the spring.
I did not know that. Thanks for the heads-up. What is the reason for the beveled edge to go down?
I also had to get U-bolts what were longer to accommodate the 1" blocks. So I have a set of brand new U-bolts if anyone is looking.
BoureeOne
BoureeOne
Madisonville, La
Keeps from causing a pinch point on the springs under accel decal and when flexing the springs out.
Funny, I was sitting her talking to my wife and showing her the pic and your comment... And I said it makes sense that they should be flipped because of the flexing of the leafs. Thanks again for noticing it.
Can71
Redwood city
Bought the same kit from wildhorese and had the same problem. I finally determined they had the wrong pins in the kit. Informed them in December of the problem, having the wrong pins in the kits,sounds like they have not checked/fixed their inventory
BoureeOne
BoureeOne
Madisonville, La
BoureeOne
BoureeOne
Madisonville, La
Well they might have. I bought this kit 3yrs ago. Just now getting to the point of putting it in.
jcpetrson
BoureeOne - Thanks for posting those pictures! My PO must have felt that the self adj parts were too much hassle and just ran the bottom blue spring from one brake to the other. I'm not going anywhere until that's fixed.
I don't know why I didn't check my front brake setup after I bought the truck. I did eyeball and have plenty of thickness to last.
